HID Aim repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by onerpm, Jul 5, 2006.
  1. onerpm
    onerpm New Member
    477
    MN
    There have been some threads here about people having problems with their headlights aiming low and stuck there; not sure if that applies to halogen & HID, or just HID. Anyway, my HID's on my 2005 have been aiming way too low (on low beam) for a number of months. When I had the car in a few months back for something or other, at a dealership that I previously thought had a competent service dept. (Burnsville Toyota, MN), I complained about it. They told me the aim was fine...they tested it by comparing it to another Prius that was in for service (!!). Idiots.
    Well I took it back to my selling dealer (Walser Toyota, Bloomington MN) this week for the steering shaft recall, and asked them to look at the aim. They replaced the levelling sensor that is located in the rear of the car. Haven't had a chance to check out any difference yet.
    Other threads have noted that these seem to be a problem, can get corroded, are even easily removable and can be cleaned. I just wanted to note that my receipt said that they had installed an "improved" version of the sensor, so Toyota must have recognized that the old one had some design issue that was addressed.
    FYI.
    Rpm
  2. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    I had the leveling sensor on my 05 replaced too and the lights still pointed to low. So I disconnected the actuator arm on the sensor and taped it in position so I had the lights pointing just where I want them. I rarely have anyone in the back seat or much luggage. So I don't need auto leveling. When I took it to inspection, they said the light height was perfect.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(nyprius @ Jul 5 2006, 03:25 PM) [snapback]281661[/snapback]</div>
    If one day you blind someone due to this selfish arrogance and cause them to crash, I hope that they sue you and end up owning everything that you have.
    Go to a competent dealer who will fix the problem before someone is hurt.
  5. brasche
    brasche Member
    156
    Orlando, FL
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jul 5 2006, 08:14 PM) [snapback]281698[/snapback]</div>
    Wow, where did that come from? Anger management please!
  6. nyprius
    nyprius Member
    385
    24
    Be careful what you wish for others. It often comes back to you.
    Also, try to read a little more carefully. Did you see the part that said the inspection people said the height was perfect. That means the lights don't shine in people's eyes. Prior to adjusting the lights myself, I took it back to my dealer twice. They said they couldn't adjust the lights higher, even though they were pointing 50 feet in front of the car, meaning I was over-driving them at 35 mph or more. I set them so they are below the windshields of other cars.
  7. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(nyprius @ Jul 5 2006, 05:51 PM) [snapback]281716[/snapback]</div>
    I think this is ample indication your dealer is either incompetent or lazy. You would be advised to find a new service department, as headlight aiming isn't generally considered a "hard" repair, even on HIDs.
  8. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jul 5 2006, 05:14 PM) [snapback]281698[/snapback]</div>
    Hey, did you have a bad day today? Do you need a hug?
    Please keep in mind that very few cars have leveling lights...including a lot of Prius! De-activating the system, but still keeping the lights at the legal height should not be an issue.
  9. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 6 2006, 12:17 AM) [snapback]281808[/snapback]</div>
    The best Prius technician at Westboro MA Toyota worked on the headlight aiming. After replacing the leveling sensor, he told me he had adjusted them up as high as he could and that they were pointing at the right level according to his measure. However, when I drove, the black line of the HID lights was about 50 feet in front of the car, meaning they weren't lighting up the road in front of me. They weren't even hitting a car 3 lengths in front of me, whereas they should have at least gone as high as the license plate of that car.
    So far the dealer has been great. So I didn't want to go elsewhere. When they said they couldn't do more, I said fine, I'll do it. I don't need leveling anyway. In 18 months, I've only had a person in my back seat twice, and that was a 35 lb boy. My 110 lb girlfriend in the front seat and two suitcases in the back do not raise the headlights. So I just taped the accurator arm in a position that aims the headlights just below the windshields of oncoming and leading cars. Now they work perfectly. They shine down the road, as they should, without blinding anyone. Of course, they might point in someone's eyes briefly if I'm cresting a hill. But all HID headlights do that. Leveling doesn't seem to work fast enough to stop that.
  10. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    IsrAmeriPrius-
    You need to stop drinking coffee........good God.
  11. onerpm
    onerpm New Member
    477
    MN
    OK, I finally drove after dark last night, and my lights are perfect now that the sensor was replaced. By my eye, anyway.
    Peace, everyone!
    rpm
