Power steering failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TrinidadPrius, Aug 5, 2017.
  1. TrinidadPrius
    TrinidadPrius New Member
    Trinidad
    My power steering died but can't figure out what's the problem. These are the codes I'm getting. Any help?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,719
    1,761
    Bay Area
    You're going to need techstream to see if the power steering ecu can communicate with the car ECU or not, then figure out why it can't communicate. Either the wiring harness went bad from the PS ECU to the car ECU or the PS ecu went bad, or there's more issues that you don't know. Thats what I would do. If anyone else had this problem before, it would be nice to know how they fixed it.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Do you truly have no power steering, or just lights and codes? If the former, +1 on checking the harness and connections to the power steering ECU. If the latter, I would check the health of the 12 volt battery first because sometimes that can cause problems with ECU communications. Let us know what you find! Good luck!
    NutzAboutBolts likes this.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Check the fuse
  5. TrinidadPrius
    Trinidad
    I check all the fuses pulling and putting back some and now everything is back to normal. Strange
  6. NutzAboutBolts
    1,719
    1,761
    Bay Area
    glad you got it fixed, that is strange...
    TrinidadPrius likes this.
  7. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Sometimes reseating a loose fuse will restore the circuit. If the problem reoccurs, check the relevant fuses with a resistance meter.
