Check engine light resolved?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by bigmichaelkim, Aug 4, 2017.
  1. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Hello, my car's check engine light came on and lo and behold it was the less than ideally tightened fuel cap that was the culprit. Either way, I used my obd 2 scanner to erase the codes and my cars check engin light went away but my obd 2 reader still read p1423 permanent. Should I be concerned? Or am I fine because the check engine light is gone and haven't come back on yet? Pictures included for reference. IMG_0436.JPG IMG_0437.JPG
    iPhone ?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    Why did you erase the code without the problem fix? I would look into the fuel leak since that's a safety concern. Have a shop do a fuel leak test to see where the leak is coming from. erasing the code is just ignoring the problem. Hope you get it resolved.
    RCO likes this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It was his fuel cap that wasn't tightened, he said so, which would give a "gross fuel leak" if you went round a corner.
    RCO likes this.
  4. Mendel Leisk
    41,396
    Doesn't the gas cap code go away after a few days driving? (n)
    kithmo and RCO like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Most codes go away themselves after x number of starts (boot ups if you like) if the fault is rectified, but they are usually logged.
    IIRC you can clear codes yourself in maintenance mode (can't remember if that includes logged codes).
    RCO likes this.
  6. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    Some codes are permanently logged, they won't turn the check engine light on, it's just that there is a permanent log of it. If the light doesn't come back on after the readiness monitors are complete then you are good to go. Hope this helps.
    RCO likes this.
  7. NutzAboutBolts
    1,693
    1,738
    Bay Area
    ah ok, damn I missed reading that part.
    RCO and kithmo like this.
