Code Reader and Software?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fishyjim99, Aug 6, 2017.
  1. fishyjim99
    fishyjim99 Junior Member
    Westerville, OH
    I have been extremely lucky with my 2004 Gen2 - 165,000 miles and just now getting triangle of death. I see old posts about code readers. And now I see $25 code cable with USB that looks like it just plugs into computer (and I assume running $25 copy of Toyota Techstream software). Has anyone tried that combination? Does it really work to identify bad battery module?
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    If you are talking about a mini VCI you should order it. Do you need a Windows laptop to run it on. the drivers like 32 bit operating systems. You will basically have a year old version of the Toyota factory diagnostic system which is called techstream.
  3. johnjohnchu
    johnjohnchu Active Member
    212
    104
    32-bit Windows 10 can automatically recognize the cable. Hence no additional device driver installation is necessary. Latest TechStream is available on the web if you search around.
