Phone usb connection randomly stops working?
Discussion in 'Prius v Audio and Electronics' started by PreusV, Jul 31, 2017.
  1. PreusV
    PreusV Junior Member
    Chicago
    2013 Prius v wagon
    Just bought a 2013 Prius V 5 with Nav. When I connect my iPhone 7 to the car through usb the connection will work for 1/2 to an hour and then just stop working. The phone will keep playing whatever is playing but nothing comes out of the speakers. I then connect it to AUX to keep listening but I lose some functionality that way. Any idea why this is happening?
  2. mikefocke
    4,043
    1,839
    Sanford, NC
    My bet is the v (note the lower case) has a chip that drives the USB that gets hot and stops functioning. Of course the same could be said of the phone.
  3. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    The iPhone 4 is the newest iPhone model listed in the 2013 Prius v navigation system manual as being compatible. It's been documented on a number of car forums that newer iPhones draw more power than Toyota's USB ports can provide. Your best bet is to stream audio from your iPhone via Bluetooth or an aux-in cord and to charge your iPhone by connecting it to a USB adapter plugged into a 12V power port.
    This means you'll have to control music streaming from your phone. We use dash mounted iOttie phone holders in our vehicles and stream only via Bluetooth.
    Attached is a photo of the type of USB adapters we use in our Prius v Five/ATP and other vehicles.
  4. PreusV
    Chicago
    2013 Prius v wagon
    Awesome, thank you both very much. Stinks the car can't handle the higher power draw but it's good to know what the issue is. Is upgrading to the head unit from the 2015+ Prius V a way to solve this? I could go with the cheaper unit as I don't need Nav (use Waze on my phone)
    Is there a way to remove the bluetooth connected devices from the previous owner?
  5. Offline
    646
    240
    Lenexa, Kansas
    A newer head unit won't help. Explore the settings in your Prius v head unit (or read the manual) and you should see how to delete devices and contact lists.
    The JVC head unit in our Prius v Five/ATP does a nice job of reading emails and text messages from my wife's iPhone 7 and my Samsung S5 but iPhones don't allow using the canned replies.
