Sylvania H11 bulb fit issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cooper999, Dec 2, 2014.
  1. cooper999
    cooper999 New Member
    Rockville, MD
    Hey folks,
    I'm attempting to change out a burnt out headlight bulb for the first time. At the auto parts store, the bulb that supposedly fits my 2011 prius is a Sylvania H11.
    I got the old bulb out fine; however, the replacement Sylvania bulb has a couple of tabs at the base (you can see the two little tabs on the right side of the picture at the top and bottom of the point where the bulb inserts) that the original bulb didn't. I'm having problems getting the new bulb to fit in the housing. Has anyone else had this issue? How did you resolve?
    Thanks for any assistance!
  2. alekska
    alekska Active Member
    435
    138
    Atl
    Are you sure you took out a low beam bulb? High beam and low beam use different bulbs
    - Alex
    xliderider likes this.
  3. cooper999
    Rockville, MD
    UPDATE-
    Alex, you are correct. I was trying to change the wrong bulb!
    All is resolved, thanks. Time to think about how shapes fit together now :)
  4. mariposer
    mariposer Junior Member
    33
    17
    Hot Springs Village, AR
    Three Touring
    Does a Sylvania SILVERSTAR ULTRA 9005 replace low beam or high beam on a 2015?
  5. StarCaller
    StarCaller Senior Member
    1,283
    732
    Cedar Crest, NM, USA
    high beam/
    low beam is h11/
