ABS VCS BRAKE EXCLAMATION lights code c1345
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by David M Fleisch, Aug 9, 2017.
Tags:
  1. David M Fleisch
    David M Fleisch New Member
    Florida, usa
    Three Touring
    Please help, I was trying to reset the weight sensor with a foxwell 630 and I accidentally deleted the abs ecu memory and now I have all these lights. Can someone please advise me on what to do to remedy this ? 20170809_195252.jpg 20170809_195346.jpg 20170809_195252.jpg 20170809_195346.jpg 20170809_195351.jpg
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
  3. David M Fleisch
    Florida, usa
    Three Touring
    All I have is this foxwell, which I'm now going to return. I'm guessing to do the recalibration I must have a techstream ?
  4. Travis Decker
    139
    116
    Portland OR
    To the best of my knowledge yes
  5. David M Fleisch
    Florida, usa
    Three Touring
    I have a mobile tech coming in the morning, I guess I'll just have to pay someone :(
  6. Travis Decker
    139
    116
    Portland OR
    You can get a mini VCI off Amazon and do it yourself
  7. ChapmanF
    18,417
    In Gen 3, there's a way to trigger the linear solenoid learning with a jumper wire at the diagnostic port, for those occasions when you don't have Techstream and a laptop handy. If that's provided in Gen 3, I would be pretty surprised if it isn't also in Gen 2. You might at least look in your repair manual on techinfo.toyota.com and check (whether it's possible, and to avoid assuming all the details would be identical to the Gen 3 link I gave).
    -Chap
