Using 12v 10 watt solar panel to charge the 12v AUX battery.
Discussion in 'Prius c Technical Discussion' started by PHANG HAN CONG, Aug 10, 2017.
  1. PHANG HAN CONG
    PHANG HAN CONG New Member
    MALAYSIA
    I am from Malaysia, may I know is it possible to charge the 12v aux battery using a 12v 10watt SOLAR PANEL and charge controller ? It is possible to hook it under the hook fuse box positive terminal ( the terminal for jump start ).
    Thanks.
  2. Mendel Leisk
    41,434
  3. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Yes, it should work. I would suggest using a charge controller since the Prius' battery is so small.
  4. PHANG HAN CONG
    MALAYSIA
    Yeah. Will try it soon and hope it won't burn the whole system.
  5. drysider
    823
    336
    Liberty Lake WA
    No reason it should. If the battery was bigger, you could eliminate the charge controller. Now you need to rig one up to charge the HV battery.
