Prime Driving Habits
Discussion in 'Prime Main Forum (2017-2022)' started by HPrimeAdvanced, Aug 13, 2017.
  1. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Have your driving habits changed since you started driving your Prime?
    I now favor driving on surface streets so that the length of the drive is shorter to accommodate my electric range. I was surprised that frequently ETA's for freeways and surface streets is the same due to the traffic situation here in Socal. What habits or experiences have you noticed driving your Prime?
    joachimz and Richter915 like this.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Yes, since Prime offers more EV power & capacity than the PHV.
    HPrimeAdvanced likes this.
  3. Richter915
    Richter915 Junior Member
    New York
    I have become the slow right lane below the speed limit driver I hated in my early twenties (I'm only thirty though geez). I watch the little blue bar and rarely if ever go above it when accelerating.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    i used to glide when going downhill on fwy in particular, sometimes accelerating up to 80 or so t the bottom of the decline, now i leave the cc at 70ish and re-gen, same for higher speed surface roads (e.g. 40 up), less gliding, more re-gen
    huskers and HPrimeAdvanced like this.
  5. bwilson4web
    16,187
    The first changes comes from driving any Prius. The car gets better fuel economy on slower, more direct routes and stops have a much lower impact due to regerative braking and high efficiency when accelerating. This is common from the Gen-1 forward and leads to shorter commuting distances by driving a direct route.
    With the prime, I will often choose to shop where there are free L2 charges, especially on the route home. But @john1701a points out the improved control laws keep the engine off more than our Gen-3. It also keeps the more efficient engine in peek efficiency mode. This means I can drive more like the dumb car drivers especially in EV mode.
    Then I take delight in left-lane high speeds to tease the dumb SUV drivers to keep up and burn up their gas money.
    #5 bwilson4web, Aug 14, 2017
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    One habit I find myself doing is going on Google Maps to see how far I'm going on a particular trip or trips and if I need to stop by a Charge Point along the way. (ok, I admit I did this with my PIP also when I owned them):cool:
    Richter915, jaqueh and HPrimeAdvanced like this.
  7. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I did a lot of thinking and planning with PiP. I mostly just drive with Prime.
  8. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I've been more content in following slower cars because the gas mileage and EV range is soooo dependent on speed an acceleration, there's much more of a difference.
    My 2010 Prius didn't have that much of a difference unless I was trying to hypermile, which doesn't really work for my commute.
  9. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Uncle Bob, that Prime is fun at speed, ain't it!! But oh shucky darn, then my mileage drops to, .... 60 miles per gallon!! Oh no, what am I to do!!, Har, har
    priuscatprimeguy and Bob Comer like this.
  10. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Yeah I used to shop exclusively at this Trader Joe’s in Berkeley. Now that I have a Prime, I only go to grocery stores with ChargePoints or Volta’s so I can also charge my car up while shopping. I don’t even care if the groceries are more expensive, I’m getting my car charged dammit!
  11. priuscatprimeguy
    2,730
    2,640
    spell "dammit I'm mad" backwards:p:D
  12. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Cooooool!!
    priuscatprimeguy likes this.
  13. Team ChargePoint
    Team ChargePoint Active Member
    171
    106
    Campbell, CA
    Mind blown.
  14. priuscatprimeguy
    2,730
    2,640
    lol, good Gif:cool:
  15. scm2000
    scm2000 Active Member
    164
    125
    Only have had my Prime for 10 days. but here are the changes so far:
    1. I no longer accelerate rapidly to the speed limit from a light, just to brake rapidly for the next light, or traffic slow down... I'm accelerating smoothly and looking further down the road to know if there's any point in making the speed limit. Basically I'm trying to maximize my score.
    2. I'm looking farther down the road and planning my stops -- Especially if there is no car behind me... I'm coming to a more smooth stop, and in some cases timing the lights for no stop at all.
    3. I use more of the entrance ramp to come up to merge speed -- conditions permitting. There is no point to be going the speed limit before the merge portion of the ramp. If there's cars behind me on the ramp... I accelerate faster.
    3a. I use more of the exit ramp to slow down. In other words.. prior experience tells me there's a red light at the end of the exit ramp even If I don't see it yet.-- this is route specific.
    4. I choose my routes based on shortest distance rather than shortest time.
    5. I adjust my work schedule to allow for time to charge if I know I will have after dinner driving.
    6. I think about how much rush hour traffic slow downs are extending my EV range... and how normal cars are burning gas idling.
    7. I only use the AC if it's too hot, or I have a passenger. I normally set the AC to 75 when I use it... if it's 75 outside, but the car is hot from sitting in the sun... I open windows to cool down the cabin. On rainy days, the windshield can fog.. so I turn on the defogger until the fog is gone, then turn it off, rather than forget it on.
    At first the point was to replace a 2007 Prius that got 45 -50mpg by driving it like a Prius... Then the point was to fit the commute within the EV range to minimize gas usage... now the point is to minimize electric usage too.
    Richter915, heiwa, john1701a and 3 others like this.
  16. Mark57
    2,945
    2,740
    OK
    Well said!
  17. Richter915
    New York
    great post! I definitely do all of the above.
  18. Bob Comer
    708
    460
    I do pretty much everything but the A/C, I run it all the time. I mostly use it in eco mode, but if it's really hot, I'll switch it to normal and full flow. There's just no sense in me being uncomfortable just for a MPG or two. I averaged 89MPG (calculated) on my last gas tank, which is better than toyota's MPG and eMPG numbers calculated for me commute.
    I told someone just this friday that i didn't mind slow traffic jams, as I get much better gas mileage that way. :)
    heiwa, HPrimeAdvanced and scm2000 like this.
  19. Tideland Prius
    16,547
    I would think S-Flow would allow you to use A/C and still have a reduced consumption (compared to non S-Flow A/C use). It probably does use more than if you had A/C completely off but at least you'll be comfortable.
    I have noticed that the automatic S-Flow (btw, the Prius is the only one with S-Flow tied to the automatic climate control) doesn't do "all seats" automatically. It appears to only switch between "Driver only" and "front seats only". Anyone else noticed this?
    Nic Steussy and HPrimeAdvanced like this.
  20. scm2000
    164
    125
    I'm like that with heat. It doesn't get very hot here, but when it gets into the 60's I've got the car heat up at 79 or 80.. Did that a couple nights so far and as far as I can see it doesnt effect things much if you're in HV mode anyways...
    Bob Comer likes this.
