brake light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bigsky, Aug 9, 2017.
  1. bigsky
    bigsky New Member
    ohio
    how long will a hlogen brake light last? i have 47,000 miles on my 2014 prius base----i was told 211$
    52,188
    welcome!
    ouch! is it that hard to change? i'm surprised it burned out already.
    edit: i see you have to change the whole led assembly. i wonder what that cost?
  3. fuzzy1
    10,554
    Your 2014 brake lights are LED, not halogen or any other form of incandescent. They are supposed to last the life of the car.
  4. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The LED brakes lights definitely should not have all burned out in that short of time. I would troubleshoot what is wrong further and not just jump into replacing the whole taillight assembly.
  5. bigsky
    bigsky New Member
    ohio
    Does the fact that the LED running light works fine but when I step on the brake the light does not get brighter indicate that it is a light assembly problem or a wiring / resister problem ?
  6. Mendel Leisk
    41,748
    Are your brake lights constantly on, even with headlights off, in daytime? That's not how it should be; they should be off until you push brake pedal. There's a switch monitoring brake pedal position, that activates brake lights whenever you step down slightly on brake: maybe out of adjustment?
  7. RRxing
    RRxing Senior Member
    2,553
    1,825
    NEPA
    This - Start with checking the brake light switch behind the brake pedal. The LEDs should last the life of the car...
  8. bisco
    52,188
    is the led running light supposed to get brighter when you step on the brake? i've never heard of this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I assume you mean that's because the LED running lights are in the front? ;)
    +1 on @RRxing's comment. Check the brake light switch.
  10. bisco
    52,188
    if the brake light switch isn't contacting, i thought the car wouldn't start?
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    True, but what if it's always on?
    OOOHHH!! Easy way to check. Try to put it in ACC or IGN mode rather than READY. If it goes to READY when you hit the power button without stepping on the brake pedal, the brake switch is not opening. Sound right?
  12. bisco
    52,188
    yes, and the brake lights should also be on all the time.
  13. jerrymildred
    11,517
    14,157
    Tampa, FL
    Just for reference:
    Car in READY, headlights off = no lights in back. (DRLs are on.)
    Car in READY, headlights on = some light in back.
    Car in READY, headlights and brakes on = lots of light in back. (Plus the middle light.) I didn't try it w/o headlights on, but I think it's the same.
    It's hard to tell if the brightness is due to more bulbs or higher voltage, but there are no lights in back without the headlights being on.
    Raytheeagle, bisco and Mendel Leisk like this.
  14. bisco
    52,188
    thanks jerry, i had no idea there weren't separate brake lights. so if the brake lights are always bright, they won't get brighter when you step on the brake.
  15. jerrymildred
    11,517
    14,157
    Tampa, FL
    I'm not sure we're talking the same language. ;) But, if the switch is always on, the brake lights will always be bright and (if I understand the scheme) you won't be able to put the car into IGN or ACC modes.
    I should have been more thorough with my pictures, but was in a hurry. I may try to do it again with all possibilities and in a systematic way, but probably can't do that this morning.
  16. bisco
    52,188
    if i step on my brake with the car off, the brake lights come on. so would they ever shut off if the switch was always made?
  17. mygel
    mygel Junior Member
    46
    24
    Slovakia
    as long as you step on your brake with the engine on or off (with the lights switched on or off), red brake tail lights (and middle one) should be always on until you depress brake pedal, but im not sure cause your car is probably more spaceship than car.. .;)
  18. bigsky
    bigsky New Member
    ohio
    Thanks for the replies---Jerry,in the third pict ----headlight on and BRAKES on ---lots of light in the back on my right sidebut not on the left---The left does not get bright when I push the brake peddle down---and it should just like the right side.Does this indicate that the whole assembly is bad or does this indicate that I have wiring problem going to the brake light assembly? AGAIN THANKS FOR ALL THE REPLIES
  19. jerrymildred
    11,517
    14,157
    Tampa, FL
    Hard to say without some investigation whether it's wiring or the light itself. I hate automobile wiring ... and I'm an electrician!
    I think that I would first try removing both rear light fixtures, if it's not ridiculously hard to do, and find a way to support them and connect them to the opposite sides. See if the problem follows the light or not.
    Duh! I should have remembered that. Serious senior moment here. I'll shut up and sit down. :oops:
  20. Mendel Leisk
    41,748
    Yeah me too.
    jerrymildred, prifahrer and bisco like this.
