Check your Cabin Air Filter Today!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, May 5, 2006.
  1. cyberpriusII
    1,153
    1,730
    Mars Hotel
    I broke a nail....actually I am lying, mine are all chewed to the quick...:oops:
    Stevewoods and ETP like this.
  2. Okinawa
    Okinawa Senior Member
    1,333
    320
    I forgot to take the damper off on mine one time. When I released the glove compartment door and it fell down the damper came off and disappeared. I looked everywhere in the area behind the door. Finally after about 3 months I found it in a small crevice back there and put it back on. If you just keep looking you may find your's hiding back there somewhere. Look back on the right side and down where the damper was connected. Mine was laying in a crevice there. Good luck to you.
    #262 Okinawa, Jul 6, 2016
    CatsAreGods and ETP like this.
  3. Stevewoods
    Stevewoods Senior Member
    656
    1,096
    Seattle, WA
    I much prefer the Prius design, with no screw holding the damper to the actual "door."
    Camry has a short screw that needs to be removed first. Said screw always rolls somewhere on the floor mat out of sight.
  4. haynesmarch
    haynesmarch New Member
    London, UK
    2016 Tesla Model S
    Active
    I clean my filter once a year and if it needs - change it.
    RCO likes this.
  5. cyberpriusII
    1,153
    1,730
    Mars Hotel
    I once had to change out four in a week because of my mousy friends.
    RCO and CanuckPT like this.
  6. timmyjane
    timmyjane Junior Member
    87
    SC
    Amazon delivered so I changed mine today.
    CanuckPT likes this.
  7. johnjohnchu
    johnjohnchu Active Member
    211
    104
    I normally just cut up typical home central A/C filters for the Prius cabin air filter. It costs almost next to nothing. DSCN4441.JPG
  8. JC91006
    JC91006 Senior Member
    16,737
    8,549
    You're not replacing the filters often enough...especially when they cost next to nothing. That old one looks horrendous
    SM-N900P ?
  9. johnjohnchu
    211
    104
    It was an extreme case, since I totally forgot about the cabin filter for a while a few years back. I do replace these filters every six months or so now.
  10. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    Bought my OEM filters online for $15. Dealer wanted $26. In my 2016 they call it a cabin pollen filter. It was very dirty after 12 months. I will replace it twice a year with a new one. I don't skimp on filters, and I never "blow out" or vacuum old filters. My engine air filter also looked quite dirty after only 11,500 miles. New one was $12. I have no problem buying fresh filters and replacing the dirty ones. 10 minutes or less. (Oil change every 5k. Keeping this car for 15 years.)
  11. cyberpriusII
    1,153
    1,730
    Mars Hotel
    Hit up Rock Auto. Prius Cabin filters are about $3 to $3.50 depending on the day.
    ETP likes this.
  12. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    I recently bought this Prius and was disgusted by this.
    SM-G935P ?
    Prodigyplace, ETP and bisco like this.
  13. bisco
    51,529
    e-u!:eek:
    ETP and Mendel Leisk like this.
  14. ETP
    2,802
    1,170
    Auburdale FL
    At least it appears to be working. Got your money's worth out of that one.
    BTW keep telling my daughter to not park under trees.
  15. ETP
    2,802
    1,170
    Auburdale FL
    Pretty cheap on ebay. Somewhere I posted a real cheap site that actually sell OEM filters in Peking.
    Still can get both. They were actually in an OEM box even though it said OEM quality.
    Engine filter:
    2pcs OEM Quality Engine Air Filter for Toyota Prius C 2012-2014 17801-21060 | eBay
    Cabin Air Filter for Toyota 4Runner Avalon Camry Corolla Highlander Land Cruiser | eBay
    #275 ETP, Aug 18, 2017
  16. cyberpriusII
    1,153
    1,730
    Mars Hotel
    As I have said many times. This filter is not all that important.
    Yeah, try to keep it clean so that you don't get some really rancid smell in the car, but other than that, any sort of filter that fits is good enough....I still swear by TYC -- around $3-$4 each on Ebay or Rock Auto.
  17. bisco
    51,529
    no-no-no, i get the expensive gem from the dealer with charcoal. save your lungs!:eek:
  18. cyberpriusII
    1,153
    1,730
    Mars Hotel
    Sounds like a good way to get black lung disease.
    Prodigyplace likes this.
  19. bisco
    51,529
    try it, you might like it.
  20. cyberpriusII
    1,153
    1,730
    Mars Hotel
    Getting enough charcoal in my lungs thanks to the summer wildland fires, thank you.
    Get over it people. A paper towel would serve as an O.K. cabin filter -- although I don't know how much air flow it would allow.
