16 or 17 in wheels
Discussion in 'Prime Accessories and Modifications' started by vern748, Jun 8, 2017.
  1. vern748
    vern748 Member
    46
    45
    Sonoma
    Hi All,
    Love my Prime. Love it love it, except for the wheels. Thinking of getting some 16in Enkei rims. Has anyone had experience with changing the wheel size on the Prime. Yes, there is a bunch of hot air on the Prius thread about things uninteresting and unrelated. I am interested in someone's first hand experience with changing their wheels o the PRIME.
    The plan is to get some 16in wheels running Low Roll Resistance tires. Not overly interested in performance or cornering but mainly impact of comfort and ride feel. I would assume the 17in would be pretty harsh and for me the 15in wallows and vague. Hoping the 16in are just right, with good feel and limited impact in overall mileage/performance.
  2. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    The standard Prius comes with 215/45-17 tires on certain models. The ride quality is good. You might even find a set of take-off wheels & tires. By the way, I do not find that the Toyo tires on my Prime wallow. I run the recommended cold inflation pressure, 36 front & 35 rear (I hope I remembered that correctly)
    tirerack.com is a great resource for many factors about tires. The Michelin Premier A/S is their pick in that size for the best ride comfort.
  3. Mendel Leisk
    41,842
    In 215/45R17 my pref right now is Michelin Primacy MXM4, I think they'll do a bit better (Than Premier A/S) for mpg, and have rim guard.
    I've got a set of first gen plug-in rims (15"), think they look sweet. But unfortunately can't convince anyone else in the family to switch out from the 17" OEM's. I bide my time. o_O
  4. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I absolutely hated the 17" wheels that came with my 2010 Prius 5 (V). They leaked, they had failures, they got less gas mileage than 15"s, the ride was rough and not particularly sporty to make up for it.
    I had my first ever blow out on one of those tires. (it's a scary experience!) It's one of the reasons I ordered a prime, just to get away from those wheels. And yes, I took care of them like you should.
    It was really the only thing I disliked about my Prius over 7 years of ownership...
  5. a_gray_prius
    2,927
    783
    IL
    Changing your tires should really be your first priority. LRRs are going to be kind of vague no matter what you do. Upsizing wheels is unlikely to make a huge difference in that regard. This goes doubly if ride quality is important to you since a lower profile tire is almost certainly going to be more harsh.
  6. Silent Propulsion
    42
    45
    Lake Havasu City Az
    20170819_103218.jpg I just had these installed today. Tires are 225/45/17. 20170819_103218.jpg 20170819_103306.jpg 20170819_103218.jpg
    Rashid K, RMB, Montgomery and 2 others like this.
  7. mhye01
    mhye01 Member
    57
    Woodland Hills
    Silent Propulsion likes this.
  8. Silent Propulsion
    42
    45
    Lake Havasu City Az
  9. Silent Propulsion
    42
    45
    Lake Havasu City Az
    Gabe29 likes this.
  10. mhye01
    mhye01 Member
    57
    Woodland Hills
    Looks amazing! The only thing i hate about the prime is that the wheels look way too small for the car. Glad to finally see one with shoes that "fit"
  11. a_gray_prius
    2,927
    783
    IL
  12. Silent Propulsion
    42
    45
    Lake Havasu City Az
    Koenig Illusion.
  13. Bob Comer
    708
    460
    Have you noticed any change in gas mileage?
  14. vern748
    vern748 Member
    46
    45
    Sonoma
    Hi All,
    Thanks for responding, and it is about time that I followed-up on my own thread.
    I have installed 205/55-16 on my Prime
    Wheels are from CostCo made by Velox
    Tires are Bridgestone ecopia ep422 plus
    Mileage:
    I have noticed a slight drop in mileage. Using Fuelly I reported
    64.7 MPG over 13,973 miles of driving from Feb - July
    On July I changed to the new wheels and tires. Since then I have reported
    63.1 MPG over the last 4,300 miles of driving from July - Sept
    This is a decrease in MPG of 1.6
    Some of this can be attributed to the wheels and tires and some to the change in temperature. Since the AC will impact mileage and these have been some hot months, the AC is likely the greater cause.
    Feel:
    The feel is much better, but was slight nervous at first. As the edges of the tires get worn in, there is no longer an over-steer feel. Corners are very confident at speed. With the 15's there was a bit of a wallow and squirm. Comfort is good, without being harsh. Based on the 16's, I think the 17's would have been harsh. Love it love it.
    Just an FYI;
    Stock wheels and tires were 34lbs.
    Opps, did not weigh the new wheel an tires.
    Hope this helps someone
    Vern
    Tideland Prius likes this.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
  16. mhye01
    mhye01 Member
    57
    Woodland Hills
    Are you lowered at all? The one thing i hate on the prime is the huge wheel gap but yours seems very minimal.
  17. vern748
    vern748 Member
    46
    45
    Sonoma
    Nope. Gap should be the same, all things considered.
  18. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    You bought those from Cosco? What did you do with your old wheels and tires? How are things holding up because I plan on doing the same thing to my prime. I just don't know if I should get black rims or dark gray like yours.
  19. a_gray_prius
    2,927
    783
    IL
    Suggestion: use your stock rims for snow tires and swap the wheels a couple times a year.
  20. Rashid K
    Rashid K Junior Member
    What is the name of these Velox rims? They look great. I am on the Costco site and they have two that look similar to this.
    Also, what size tires did you put?
    Thank you
