Does the 2010 really have issues??
Discussion in 'Gen 3 Prius Main Forum' started by StephenJ, Aug 20, 2017.
  1. Mendel Leisk
    41,645
    Does anyone sue? I mean: there can be lost revenue riding on this. Or they're basically God, and you don't tick God off, lol.
    Raytheeagle likes this.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    sue who?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    You trying to get this moved to FHOP:whistle:.
    m.wynn, WilDavis, bisco and 2 others like this.
  4. NutzAboutBolts
    1,699
    1,746
    Bay Area
    whats FHOP? lol
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Fred's House of Pancakes;).
    Or if we really get off the rails and into politics, Freds House of Politics:censored:.
    m.wynn likes this.
  6. NutzAboutBolts
    1,699
    1,746
    Bay Area
    I'm so confused... :sick: :ROFLMAO::ROFLMAO: I'll just see my way out before this thread gets side track.
    saltdiscus, m.wynn, bisco and 3 others like this.
  7. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    I've been reading all over online about the 2010 and I think I'm just to worried to pull the trigger on one. I can't tell in a test drive if it's using a quart in 5000 miles or 500 miles. A lot of people may not even realize it burns oil unless it's severe enough to drain the pan in a single oil change.
    I can't help but look at every one I see and wonder if they are getting rid of it because it's suckling down oil. For instance in my area I can find MANY more 2010's for sale vs 2009's. Why would that be? Probably because people are trying to get rid of them.
    It's SO sad because my daughter really wants a 3rd Gen Prius but we can only afford a 2010...I wish I hadn't have shown her a 3rd gen, she liked the 2nd Gen okay before we looked at a 3rd gen hahaha. I didn't know abut the oil issue at the time, I just saw we could squeeze a 100k mile 2010 into our budget.
    I wish there was info out there like build dates that seem more prone to real bad oil consumption.
  8. bisco
    52,094
    we all do. tell her to suck it up and drive an '09, character building!(y)
    WilDavis likes this.
  9. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    I am all about some character building and this certainly may go that direction...for me too really. I mean the 2010 does look at lot more current than a 2009 and has better crash ratings and a lot more current options. It's also not too much more expensive so it's hard not to really want to get it over the 09.
    Heck maybe I should look for a real cheap 2010 with a shot engine and just replace the engine.
    saltdiscus, mjoo and bisco like this.
  10. bisco
    52,094
    not a bad idea.
  11. mjoo
    mjoo Senior Member
    1,160
    1,329
    Michigan
    @danlatu, being a car enthusiast, is probably right. There are lots of examples on the internet of how an EGR system affects different car models and the results are the same. Just google "EGR cooler plugged". Although the EGR system is good for emissions and fuel economy it puts deposits on the intake manifold, valves, and EGR cooler. Here is another EGR evangelist proselytizing owners to clean the intake manifold and EGR system and also install a PCV oil catch can:
    "The clogging problem that older cars have doesn't seem occur on newer cars as much for a number of reasons: ultra low sulfur diesel fuel, more precise fuel delivery and burn, better oil separators in the PCV, and new EGR systems all reduce the likelihood of clogging"
    The '95 Saturn SL2 that I owned had lots of sludge problems, oil burning problems, and it had PCV and EGR systems. I installed a PCV oil catch can and it prevented the clogged intake manifold common to that car.
    The '07 Saturn Ion I drove was problem free and had no related issues for the life of the car. The aluminum engine ran higher compression but did not have either PCV or EGR systems.
  12. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Our 2010 also consumes oil and I've done things similar to what Ray has done above. Subjectively, it seems to have gotten better...but does still consume. Maybe I've stopped it from getting worse...who knows. At this point I've resigned myself to be forever vigilant on checking the oil level.
    After three long road trips I have concluded that most of the oil consumption occurs when the dashboard gauge is fully in the 'PWR' band. For example, going up mountain passes and such. Curiously, oil consumption appears to me much less while cruising on the freeway in the 'ECO' range of the dashboard gauge.
    Here is my recent post about it :
    Another oil burning Prius :( | Page 4 | PriusChat
    Merkey, danlatu and Raytheeagle like this.
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The 2010 model year ran from May 2009 until Fall 2010--some 15 months. The 2009 model year lasted about 8 months. Obviously Toyota built and sold a lot more 2010s than 2009s.
    I believe that oil consumption is more dependent on driver behavior. Some people keep their cars close to museum display condition. Others beat the crap out of them.
    Every used car purchase is a crap shoot to some degree and the older the car the more likely something will have to be replaced sooner rather than later.
    If you aren't comfortable about buying any 2010 then don't. No car is worth losing peace of mind over. A newer car will have a more contemporary look. To get the features in a Gen2 Prius you needed to trade up and get a Gen3 with an option package. Look for and download the sales brochures for every model year so you can identify the trim level of the car.
    When there was leftover MY2009 Prius inventory (for the first time) the debate was over the 2009 leftover at a discount or the new 2010 at MSRP. Those who bought the 2009 believed they were getting a better car at a better price.
    I'm sorry the daughter wants a Gen3 and can only afford a Gen2. Is she going to be "all in" on the car or will she also have some money put aside for the eventual repairs and maintenance that will be needed? Does she intend to learn how to do the small stuff on the car?
    For many of us our first cars were bigger POS and we had to walk miles to school, uphill, both ways, in blinding blizzards.
  14. Tideland Prius
    16,566
    Keep in mind that it's bluetooth streaming audio (for music). Bluetooth for phone is included on Prius III/Prius Three and higher (basically if you have the JBL audio system with or without navigation) for 2010 and 2011.
    It's possible because of the volume. The 2010 model year was unusually long. The car was launched in May 2009 and the 2011s didn't arrive until Sept 2010 so there's definitely more units available.
    We don't know if Toyota changed anything for 2011 or part way through 2010. Manufacturers may make changes at any time without issuing a TSB if they think the value of a TSB isn't worth the value of having people complain down the road.
    You can either tell your daughter that the 2010s aren't worth it (even if it's within your budget) because of the potential issues that may cause problems or end up costing more vs. a 2009 which may be more reliable since it's the end of the product cycle. And perhaps say that she can upgrade later when 2012-2015 models (so the updated Gen 3s) come down in price. That or just wait a few more months and hope more 2011s show up within your budget.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    2012 Prius c?
    Would that be in the price range?
    #55 The Electric Me, Aug 22, 2017
    Grit likes this.
  16. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    No, I have remained with the original 5K mile interval before Toyota later changed to the 10k mile interval.
  17. JC91006
    JC91006 Senior Member
    16,780
    8,575
    Many reports of 2010s (all turd gens apply) with major failures before hitting 200k miles, either it be blown head gaskets, clogged EGR systems, or bad oil burning issues.
    I guess all cars have their demons
    #57 JC91006, Aug 25, 2017
    NeilPeart, m.wynn and Mendel Leisk like this.
  18. bisco
    52,094
    This 4,000 rpm limiter from 2013 on is interesting.
  19. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    The 2011 is a 2010 with all the recalls done, you might want to stretch your budget just a bit for the 11. As far as rattles go, there is a correlation between tire pressures and the rattles, the higher you pump up the tires, the more rattles. Another advantage to the ten 3 is no bladder in the fuel tank, so maybe you should consider an 11.
  20. Mendel Leisk
    41,645
    How do you figure? The recalls I can think of are the inverter protection, brake master cylinder and air bag, and they all came along much later than 2011.
