Could some combine the Hybrid and EV battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by drsacha, Aug 20, 2017.
Tags:
  1. drsacha
    drsacha Junior Member
    29
    Tempa, FL
    Still learning. Someone advised me that the EV part of the hybrid battery on the Plugin 2012 is available only when charged. Could someone hack the Plugin to make the full hybrid stack available during hybrid mode. On long drive I see my battery fully charged, hence was assuming it will be better if the full battery is available in hybrid mode.
    Just to let you know my current apartment does not have facility for charging hence have not charged for sometime now. Thanks.
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    Untrue. The full pack is always available. I often regenerate from hybrid mode up to a couple EV miles on a long downhill with my 2012.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    That is true, but I think it's not exactly what @drsacha is asking. If I understand correctly, it's a way to make the computer treat the whole battery as a hybrid battery and seek to keep it hovering around the same percentage of charge as the regular hatchback battery. That would be a whole lot more available kWh.
    My thought is that, first, there would be little improvement in gas mileage, just as there is not a lot of difference between a new battery and one that is rather badly out of balance.
    Second, if that could be done, you would lose most of your capacity to store energy on long hills when on trips beyond your battery range. Which ties in with the full pack always being available. You just need a lot more regeneration (bigger hills or more stop signs) to see it happen.
  4. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    You'd get poor fuel economy if it was using the ICE to charge the battery up to "full". That's why it will only charge to 30-32% SOC (I forget exactly) in hybrid mode. As said, if you're getting enough regen it can bring it back up into EV mode availability.
  5. bisco
    51,833
    op's question is confusing. hacking the computer is not going to charge the battery. you have to plug it in, or drive down mount mckinley.
  6. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Probably one way to look at it is that in hybrid mode the system will maintain close to the state of charge when it was started. To do this it will only use the range of battery capacity that would be available when the Prius automatically enters hybrid mode at a low state of charge.
  7. drsacha
    29
    Tempa, FL
    Correcting my confusion. Took an hour ride in a high gradient neighborhood and fond the battery once 100% in hybrid mode then switches to charging the EV mode too. Was getting like a mile possible on EV mode. Did not go anything beyond that. I think that is good. Thanks again all for the insightful responses.
    jerrymildred and bisco like this.
  8. bisco
    51,833
    wow, that's impressive! i've never gotten anything around these flatlands.
  9. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    The most I ever regenerated was from 50% HV (zero EV) to 100% full EV. This was in Yosemite, where you're completely empty at the top of Glacier Point, and 16-20 miles of endless downhill back to Yosemite Valley. Just keep riding the regenerative brakes!
