Oil filter wrench
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eliteconcept, May 19, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    Sure won't HELP it. Breaker bars are cheap.
    frodoz737 likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    Yep. As tight as the things get after being in service (even when torqued "on" correctly), use a breaker bar to bust it loose initially. Saves not only your torque wrench, but your ratchets too.
  3. Mendel Leisk
    41,900
    ^ Ditto. I've used a torque wrench a few times to loosen a stubborn nut. Set it to a really high value. But always hated myself after. :ROFLMAO:
    Then picked up a 3/8" breaker bar. Mine doesn't have ratchet mechanism, just a swivel head, so you can flip the handle 180 deg. About $10 I think.
  4. Former Member 68813
    3,524
    983
    US
    the seller answered my email. mystery solved.
    "We are afraid that a torque wrench may put too much force on this item and may cause a damage, so there is such warning for it.
    Also, we raised the price to prevent order because this item is now out of stock."
  5. qdllc
    qdllc Senior Member
    1,377
    400
    I think that's the danger. YOUR wrench might do fine, but if someone broke their torque wrench loosening a stuck fastener, some moron would probably try and sue over it.
  6. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    I believe they're worried about their aluminum filter tool breaking at its square drive hole if used to remove a grossly overtightened filter, NOT about the user's torque wrench breaking.
    #46 CR94, Feb 3, 2015
  7. Mendel Leisk
    41,900
    Maybe by "torque wrench" they're thinking breaker bar?
  8. Hjeff
    Hjeff Junior Member
    25
    I tried 3 things:
    Rubber strap wrench. Didn't work.
    Harbor Freight set of 4 oil filter sock-style wrenches. 65 mm slipped off.
    Oreilly's Auto parts sells a filter socket "for most toyota & lexus" that fit perfectly. Including a cutout flange that fits the outer lugs perfectly.
