Wondering what is it
Discussion in 'Gen 4 Prius Main Forum' started by ea8631, Aug 17, 2017.
  1. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Hi all, I found this part that tuck underneath the front passenger seat, I did went to dealer earlier and ask them what is that but so far no one knows the answer. Just wondering is there anyone in here know what is it for.
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    Neither the part number (G93C1-47010) nor the model number (G9507) on the label is listed in Toyota’s Electronic Parts Catalog, so I expect it’s a uniquely Canadian part. The “-47010” suffix is typical of parts first used on a fourth-generation Prius, and the UL Recognized Component for Canada listing card says it was made for Toyota by a division of Mitsumi Electric.
    I’m not aware of any sources of 120 volts AC on a Prius, and the warning notices on the label mention “connect to properly grounded outlets only” and “keep extension cord connection dry and off the ground,” so I expect the input is meant to come from a wall outlet, either directly to this AC adapter or perhaps to some other point on the car. If the AC adapter is fixed in place and wasn’t just left under the seat, perhaps it’s for pre-heating the seats; the output (4.64 A at 8.1 V DC) is only about 38 watts, which isn’t much heating.
    Since the dealer was no help, you might try contacting Toyota Canada directly; they should be able to give you a definitive answer.
    Prodigyplace likes this.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I think thats the same as I have under my passenger seat (RHD) and I seem to remember its the amp for the JBL stereo. Not 100% on this though :)
    EDIT: I have just read it mentions heater :oops:
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It says ELECTRIC HEATER on the label, so could it be the power supply for seat heating
  5. Prodigyplace
    12,626
    11,808
    Central Virginia
    Since somebody mentioned a power supply perhaps it is for a traction battery heater? Most of Canada is colder than most of the US
    Perhaps it is port installed.
    #5 Prodigyplace, Aug 18, 2017
    RCO likes this.
  6. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Yes that A/C adapter is fixed in place under the front passenger seat. Also, I did found a standard wall plug in the engine compartment, but I didn't order any block heater for my Prius. I did ask the sales lady did my Prius come with block heater standard and she said it shouldn't be.
    The sales lady that sold me the Prius said it might be for the seat heater, but I told her how come the basic version (but with heated seat, Canadian market have heated seat standard) that on the showroom didn't have it and she said she have no idea then.
    I was think about the same thing too. So far I see my Prius and the one I rejected have that a/c adaptor. But the basic version didn't have that. Wondering is it just for lithium battery only...
    I will try to find out later today from Toyota Canada thru FB since I always got answered thru this way.
  7. Prodigyplace
    12,626
    11,808
    Central Virginia
    My guess was the Lithium battery.
  8. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    8.1 volt 4.8 amp output. Hmmm?
  9. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    What does the window sticker say your car is equipped with?
    SM-G935P ?
  10. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    My Prius is a technology grade with advanced package. The only other option I have is factory remote starter.
    Still waiting response from Toyota Canada.
    RCO likes this.
  11. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Finally got reply from Toyota Canada, they said it's a battery warmer. I ask them is it only for lithium battery model and is it include block heather feature too and they just said this battery warmer is for your specific model only......
  12. Prodigyplace
    12,626
    11,808
    Central Virginia
    @Tideland Prius has something else to add to the Canadian features, apparently.
    I wonder where the connecting power cord runs. Hopefully, not through the active grille shutters :eek:
    RCO likes this.
  13. Tideland Prius
    16,602
    Hopefully they take that into account and run it through the upper grille rather than the air dam (where mine is on the Gen 3)
    RCO likes this.
  14. Prodigyplace
    12,626
    11,808
    Central Virginia
    I was thinking of that poor Alaska Gen 4 user whose EBH cord was run through the grille and the cord was later blamed on the car fire.
    RCO and Tideland Prius like this.
  15. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    The cord is located here so I think should be fine. Still try to find out if it just a plain battery warmer or it did come with block heater as well.....
    Tideland Prius, Prodigyplace and RCO like this.
  16. Dman747
    Dman747 New Member
    Montreal
    Hello , I work at a car dealership (not Toyota) but this is a keep charge for the battery , if a car is in the showroom we just plug it in , the part you are missing in the clips to go on the battery , also if you look at the bottom end of this cord , should have a regular 110v normal plug.
    This is not a battery warmer or a block heater
    pilotgrrl and RCO like this.
  17. Prodigyplace
    12,626
    11,808
    Central Virginia
    So, it is a factory battery tender?
    That's interesting.
  18. Dman747
    Dman747 New Member
    Montreal
    I don't think it is factory install
    RCO likes this.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Are you saying this is what the dealer installs to keep the car 'live' for customer demonstrations in the showroom ?
  20. Prodigyplace
    12,626
    11,808
    Central Virginia
    RCO, Your comment got eaten.
    Thanks for updating it.
    #20 Prodigyplace, Sep 14, 2017
    RCO likes this.
