Detailing a Prius
Discussion in 'Gen 2 Prius Main Forum' started by terry2336, Oct 9, 2009.
  1. terry2336
    terry2336 Junior Member
    17
    Maine
    Took my new (to me) 2005 driftwood pearl Prius to my local detailer. He says he can make it look like new but wont touch it under the hood. Do all detailers do this or can it cause major problems? Its pretty dirty under there.
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I clean Pearl under the hood every time I wash the car. It's pretty much waterproof under there. Hose it down all the time. I even put polish on items under the hood.
    m.wynn likes this.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I just take a big wet towel and wipe up all the surface dirt and dust that I see.
  4. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    Funny, when I worked downtown, I used to have my car detailed once a year. That guy charged more for the first detailing on each car because he spent extra time cleaning up the engine and engine compartment (looked showroom when he was done).
    That's what I do now, but only about 2 times per year. It's always pretty clean, though.
    I do wax the painted surfaces under the hood, inside the doors and door jambs and under the gas cap door once a year too. That way dirt and dust just wipe off.
  5. richard schumacher
    7,664
    1,046
    United States
    Some would say that running a hose into the carefully waterproofed drive compartment is nuts :_> If you do it, be sure to dry around all the ignition wires before running it again.
  6. David Beale
    5,963
    1,988
    Edmonton Alberta
    There aren't any "ignition wires". It's coil on plug. If you think the engine compartment is waterproofed, try "accidentally" driving though a deep puddle at speed and then check under the hood. Everything under the hood is waterproof. Except for submersion. It's not a submarine. ;)
  7. Coopers ST
    Coopers ST Junior Member
    51
    Colorado
    Sorry to bump a old thread, but as a detailer I don't touch anything under the hood of electric or hybrid vehicles, and rarely have a customer ask.
    I asked some detailer friends and only one does, and he only does brand new still at the "dealer" Teslas.
    Knowing I was getting a used Prius I asked this question on a detailer forum I am on and got one answer saying stay away from orange, do it at you're own risk.
  8. Tideland Prius
    16,547
    Does this help?
    WilDavis, Coopers ST and Merkey like this.
  9. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Thanks for posting that! Just to double check (because I'd hate to make a mistake here), the gen 3 engines can be hosed down without any foil or other preparation?
  10. Tideland Prius
    16,547
    Well he only covered the 2nd gen. Aside from that belt (because the Gen 3 is beltless), I'd say for precautionary purposes, just cover the same things with foil that he did (which may not be in the same place). The extra effort will be worth not having to deal with water damage.
  11. MelonPrius
    839
    516
    Nevada
    At 1:20, he talks about protecting the pulley because you cannot get the bearing wet on the Gen 2. I'll look to see if the Gen 3's have the same exposed wires that he covers, and do the same.
    Tideland Prius likes this.
  12. a_gray_prius
    2,927
    783
    IL
    Given that pretty much all Teslas (including our own) have huge plastic covers that are seemingly designed to keep customers away from any actual car components, how does your friend do anything "under the hood" at all?
    Edit: I should add a picture.
    #12 a_gray_prius, Aug 27, 2017
  13. Coopers ST
    51
    Colorado
    Don't know exactly what he does, probably just dresses all the plastic.
  14. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    On the Gen III, he specifically details covering over the ECU connection on the left (driver's) side of the engine bay. Other than that he talks generally about looking for electrical connectors and covering them over.
  15. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    I hosed mine down at manual car wash because it was pretty dirty/dusty....No problems whatsoever.
    Coopers ST likes this.
  16. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    Unless you have loose connectors or use a power washer you should be fine using soap, brushes and water hose. Picture is my 05 after cleaning it. Go slow and just be careful. [​IMG]
    SM-G935P ?
    #16 ih8spm, Sep 18, 2017
    MilkyWay likes this.
  17. MelonPrius
    839
    516
    Nevada
    I like simple. And NAB makes this look easy. Thanks for the video.
  18. Mendel Leisk
    41,317
    I just use a paint brush, one of those duster wands, and a leaf blower. Very rarely, but it looks good anyway. Never sprayed water or applied any kind of plastic treatment.
  19. Coopers ST
    51
    Colorado
    [​IMG] Thanks for the input. I did it a few weeks ago and posted a pic in a new thread about detailing the car. Here is my engine bay.
