A hybrid Filter at 50,000?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by icyrius, Sep 2, 2017.
  1. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    I just picked my car from a 30,000 miles maintenance visit to the local Toyota dealership and they are recommending these upcoming maintenance expenses (please see attached picture). I am a frequent reader of this forum and have never seen any thread talking about Hybrid filters. Toyota representant said if I do not get my Hybrid filter exchanged my Hybrid battery will go bad soon. Is this for real? Do I need to spend $299.95 as they are recommending? WP_20170902_10_24_38_Pro (3).jpg
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    This is why I love this forum- it really educates me on the recommended maintenance. Looking forward to the responses.
  3. Air_Boss
    Air_Boss Senior Member
    4,225
    1,188
    New Yawk
    As the receipt states "TRULY EXCEPTIONAL"... A "hybrid filter"....
    CatsAreGods and bisco like this.
  4. Mendel Leisk
    41,951
    Change your filters yourself, only as required. There's an engine air intake filter, and a cabin air intake filter. The latter I'm very cavalier with, just tap it out, reverse blow with some air. I've yet to change either, at 70K kms on our 2010. The engine air filter looks virtually new still.
    Hybrid filter? There is a coarse mesh grill on the hybrid battery fan air inlet on later years? Maybe that?
    I'd guess the term "hybrid filter" is some challenged service writer's attempt to describe hybrid battery FAN cleaning. Maybe. Again, this is something relatively easy to do yourself.
    See @NutzAboutBolts video on that topic, pinned at top of 3rd gen maintenance sub-forum. (Kinda guessing, that the v is very similar) I'd say seat removal is not needed. Also, you can clean the fan without completely removing it. I would leave virtually all hatch floor fasteners off, to make future removal easier.
    You'll likely find the fan very clean still, but doesn't hurt to check.
    dubit likes this.
  5. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    The Gen2 had an issue with hybrid batt cooling fan gunking up, so you need to clean the fan (note I have never done this yet). It was especially an issue with pet hair for pet owners. As far as a v, I am skeptical of the cost quoted.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just call the service department and ask them what they mean by "Hybrid Filter".
    I'd be really curious as to what answer they give you.
    CatsAreGods and Mendel Leisk like this.
  7. RRxing
    RRxing Senior Member
    2,556
    1,829
    NEPA
    "Hybrid Filter" means to filter that dealer and find another one... :rolleyes:
    scona, GregC1979, WilDavis and 7 others like this.
  8. bisco
    52,417
    poppycock. never go back to this dealer. period. at 30k, all you need is standard maintenance. look in your o/m. the only off manual thing you might consider is a tranny fluid change in the near future. don't pay more than a hundred bucks.
    Merkey and dubit like this.
  9. Prodigyplace
    12,687
    11,833
    Central Virginia
    They say to clean the intake grill on the Gen 4. If you remove the grill you can see a filter but it is not mentioned anywhere in the maintenance guide.
  10. Mendel Leisk
    41,951
    Yeah our OEM grill is basically about the same spacing as a waffle. I tucked in behind it a screen, the same stuff that's used on residential windows, maybe 1/16" openings. Maybe every couple of years I've checked on the fan, it has fine dust but not that much build-up. OTOH, we're only at 70K km's, lol, and west coast so less dust in the air I think.
  11. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    I continued to research Toyota's recommendation and it turned out they were telling the truth. First I found this manual online that showed a picture of the hybrid battery air vent inlet.
    Then I went to my car and this is what is looked like after 30K miles. Sorry for the picture quality. I could not get my phone to focus properly due to light.
    I took my shopVac and vacuumed it. This is what it looked like afterwards,
    A view from the top shows this piece is actually a filter that can be replaced,
    The mesh is plastic and similar to mosquito or screen room mesh. Now that I know I do not plan to replace it. I will only check it frequently and keep on vacuuming it. It looks very durable as long as you vacuum it gently without ripping the mesh.
    Thank you all for collaborating in this thread!!! This is the best forum.
  12. MelonPrius
    839
    516
    Nevada
    As far as cleaning, I like the v's design better than the battery vent near my back seat on my gen 3. Was the dealer going to charge you $299 for changing that filter? How much does that part cost? From your photos, it looks as if it can be changed without complicated use of tools.
  13. bisco
    52,417
    looks like a terrible location to me. something pushed under the seat could easily block it, and not be seen.
  14. Air_Boss
    4,225
    1,188
    New Yawk
    Ditto most under-seat SRS wiring (not limited to the Prius/v)... Throws all sorts of codes.
  15. Mendel Leisk
    41,951
    Just vacuuming it seems a simple and effective course.
    Still, sometime down the road, dig down to the fan itself, if only to confirm it's not bad.
  16. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    2024 Prius
    It's a legit item, and that price would include a new filter and cleaning of the fan. If it doesn't get done it will lead to hybrid battery overheating and failure. As said above, it looks easy enough to do yourself except that I recall reading you have to be careful with the fan in some way.
  17. bisco
    52,417
    if it's legit, how often does the o/m say to check/clean/change it?
    i wonder if that location is sucking up more lint? my inlet screen and filter are clean as a whistle after 54,000 miles.
  18. MelonPrius
    839
    516
    Nevada
    I vacuum the outside of the vent a couple of times a week. But I haven't gotten inside yet. Did you routinely clean the actual filter behind the inlet screen? Or when you checked it, was it already clean as a whistle?
  19. bisco
    52,417
    already clean. i carry no shedding pets, so that is one mitigating factor.
    another is different models have different numbers of inlet grilles, and different locations.
    for instance, my pip has one on the right rear passenger seat back toward the side, same as my gen 2's, but also has one on the left rear below the seat cushion.
  20. Analogkid1958
    119
    61
    Yorktown, IN
    2024 Prius
    Toyota does not include this in the maintenance schedule which I thought was odd, especially since a malfunctioning fan can lead to traction battery failure. (Maybe they figured the fan would outlast the battery? In my 2010, the battery failed at 305k miles, the fan had never been serviced and was found to be badly clogged. Are the two related? Correlation or causation? Who knows?)
    I guess the point is, if you're able to do it yourself, it's worth doing.
    bisco and Merkey like this.
