1. J Humes
    J Humes Junior Member
    26
    PDX
    Four Touring
    On the 2012 Prius Hatchback -
    The backup light bulb has a white and red wire.
    Which one is positive +?
    My Toyota dealer won't tell me.
    JR
    52,093
    nice dealer.:confused: generally, red is positive and white is ground.
    J Humes likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    or use volt meter
  4. J Humes
    26
    PDX
    Four Touring
    Thanks all - :)
  5. ChapmanF
    18,316
    Or wiring diagram.
    I've found white-with-a-black-stripe to be a widely-used ground color in Prii. (Still no substitute for checking the particular circuit you're looking at, with a voltmeter, or the diagram.)
    Uncover any of the ground points in the Prius, and you'll see scads of white-with-black-stripe wires attaching to it.
    -Chap
    Elektroingenieur likes this.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    Red is usually +positive, white and black are ground.
