Squeaky plastic hubcap
Discussion in 'Prius c Main Forum' started by zul, Sep 2, 2017.
Tags:
  1. zul
    zul New Member
    2015 Prius c
    My prius C is only about two years old and the front left plastic hubcap has begun to squeak in such a way that people on the street turn their heads and look at my vehicle.
    I took it to the dealer and the service manager said that this is simply a matter of the hubcaps aging and it is to be expected
    This seems like a cop-out ... Does anyone here know if these should be covered under the warranty such that I should get replacements for free?
  2. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day zul,
    That's very odd.
    Are you sure it's the plastic hub-cap and not something a little more serious 'inside' that wheel?
    Have you taken the hub-cap off and driven sufficiently far to be certain the noise is from the hub-cap?
    Put it back on and drive some more to confirm?
    Switch the hub-caps around to further prove it's that particular hub-cap?
    David S.
  3. zul
    zul New Member
    2015 Prius c
    I took it off, and it squeaked no longer. Not once. I should try putting it back on perhaps after I clean it.
  4. Mendel Leisk
    41,907
    Is there a spring inside, maybe lube? Silicon spray?
