ABS VSC break lights all on PRIUS 07
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eem, Sep 3, 2017.
  1. eem
    eem New Member
    bronx
    Please help me all the break lights on my prius are on i changed the brake booster a month ago. it was believed to be the issue and drove great and now the same issues arise like the booster is constantly rattling and i have to step very hard for the car to come to a stop. Its as if the brake fluid isnt flowing correctly like a build up happens im not sure tbh just speculation. Please if anyone has advise that isn't going to the dealer it would be greatly appreciated
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Did you do this yourself, a dealer, or independent? If the last two take it back for them to troubleshoot. If you did it, did you use the techstream/mini vci unit to assist you? You could have air in the line, it would need to be rebleed.
  3. eem
    eem New Member
    bronx
    Im not sure if the independent shop i went to used that device I will check tomorrow
  4. eem
    eem New Member
    bronx
    Could it be anything else? The brake booster rattles like every 10 seconds while the car is on ready
  5. bisco
    52,121
    did you get the extended warranty on the booster?
  6. eem
    eem New Member
    bronx
    Im positive the issue isnt the booster, it was used
  7. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    The brake system on the Prius is a bit particular versus other systems. The Techstream tool is pretty much necessary for successful repair of the brake system. So your repair guy will have to have something like it to work on the brakes.
