12v battery power consumption
Discussion in 'Gen 2 Prius Technical Discussion' started by psibill, Jul 1, 2006.
  1. psibill
    psibill Junior Member
    55
    When the 04-06 Prius is off and "at rest," how much power is drawn from the 12v battery to keep all the electronics working and monitoring, etc.
    I expect the power drain to be different depending on which factory options are installed, so let's just ask about the top package with all the goodies.
    Thx.
  2. tochatihu
    tochatihu Senior Member
    9,851
    3,813
    Kunming Yunnan China
    2001 Prius
    30 to 40 milliamps is what I recall.
  3. mrbigh
    3,686
    699
    Long Island, NY
    <div class='quotetop'>QUOTE(Bill-psi @ Jul 1 2006, 01:38 PM) [snapback]279736[/snapback]</div>
    The Stand-By battery load should be under 50mA with out SKS and about 85mA with it. ;)
  4. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(mrbigh @ Jul 1 2006, 08:14 PM) [snapback]279868[/snapback]</div>
    So if you could replace that energy while the car is quiet, would the ICE stay off longer?
  5. mspencer
    mspencer New Member
    101
    Council Bluffs, Iowa
    85 mA at 12 volts is about one watt.
    One horsepower is about 745 watts.
    If an engine outputs 118 horsepower for one second, it will have outputted enough energy to power a one watt load for 24 hours.
    So: theoretically yes, but measurably probably not.
  6. ConservationMatters
    ConservationMatters New Member
    North Carolina
    Can someone explain to me how much battery energy, in watts, it takes to drive Prius. If i am driving a constant 35 mph on level ground for 1 hour; can you compare the Prius energy consumption to that of (household) light bulb energy ? ? ?
    Thanks
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    If you assume 20 hp of engine output (just a SWAG*), that's about 15 kW. If your light bulb is 100W (that's a bright bulb, but it makes the math easier), that's 150 light bulbs. If you drive for an hour, the energy is about that consumed by 150 light bulbs burning for one hour. If you pay $0.10 per kWh, that would cost $1.50.
    Engine output is going to depend a lot on wind direction and tire pressure at that speed. Try riding a bicycle at 35 mph and you'll see.
    * Engineering acronym for silly, wild-assed guess in back-of-envelope calculations like this one
