Newbie here with a question about a 2010 Prius for sale
Discussion in 'Gen 3 Prius Main Forum' started by PRI6080, Sep 9, 2017.
  1. PRI6080
    PRI6080 Junior Member
    22
    I'm looking at a used 2010 Prius package 5 with the technology option. It has about 201K miles on the odometer. I know Toyota gasoline engines can go for a long time, with regular oil changes and maintenance, but I don't know much about that statement when coupled with hybrid technology.
    Overall the vehicle is in "good" condition and he's asking around $7k for it.
    Do you guys think that's a bit much?
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    There are alot of 2010's for sale due to them approaching the end of the 10yr battery life. If you truly need a hybrid, I would suggest a newer one (2012-2015) with less miles and more years ahead on main battery. No matter the brand, it is my humble opinion that when it comes to buying a hybrid, the newer, the better.
  3. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    PRI6080, which state are you located in? This way we can see if you're in a CARB state, which comes with a longer hybrid warranty.
    Is $7k your budget for the next car, or can you go higher?
  4. bisco
    52,274
    welcome!
    stay away. currently, we are seeing a ton of 2010's burning oil, blowing head gaskets and dying batteries.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Just because the warranty term for the battery has expired doesn't mean the battery is at the end of its useful life. It may die tomorrow or it may die several years from now, there just isn't any way of knowing. In 2024 Montgomery will be in the same position.
    However, the advice is sound. A newer car with fewer miles should last the next owner longer than the older car with more miles.
    Is an 8 year old car with 201000 miles worth $7000? Only you can answer that question. What else can you buy for $7000?
    Raytheeagle likes this.
  6. PRI6080
    22
    Yes, in CA. $7k a little more, maybe.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,720
    1,761
    Bay Area
    Go with 2012 and up. Read too many thread with 2010 issues like @bisco mentioned.
    PRI6080 and bisco like this.
  8. MelonPrius
    839
    516
    Nevada
    In my opinion, you should have enough money put aside to be able to afford a new traction battery. Or, you should look for a Prius that still has some warranty left on the traction battery. You will get a 10 year/150k mile warranty being in California (make sure it's a California car).
    When I started searching for a Prius, I had the same budget as you have. After reading the info here, I decided to increase my budget and get a Prius with a newer model year with lower miles.
    PRI6080 likes this.
  9. JC91006
    JC91006 Senior Member
    16,813
    8,595
    I would be concerned about oil burning and possible head gasket failure.
    m.wynn, PRI6080 and NutzAboutBolts like this.
  10. PRI6080
    22
    What does the warranty cover?
  11. b100
    b100 Member
    145
    75
    Netherlands
    I would go 2012 (facelift model) or newer
    Because of what bisco said.
  12. bisco
    52,274
    the hybrid battery. 10/150 in carb states, and 8/100 in non carb states.
    PRI6080 likes this.
  13. Ginto
    Ginto Junior Member
    28
    Some of those 2010 threads are mine.... my car just went over 215K and is becoming unreliable. Just replaced engine (213K after burning oil for
    the last 120K miles.) Currently have a P0A08 DC/DC converter issue which could be thousands more to fix.... I would go with a newer car or pay only half that price for a 2010. Based on my experience you will need the cash for repairs.
    Update... was at the dealer about to get a Gen4. Found out the fault code was tripped by a loose connection from the engine swap...
    Now not sure what to do next... at least now it has trade in value...
    ETC(SS) not to distract from the conversation but nice emergency blow photo... fellow ex-bubble head!
    #13 Ginto, Sep 12, 2017
    PRI6080 likes this.
  14. Mendel Leisk
    41,818
    You guys can't all be wrong, but ours is leading a charmed life, so far: no oil usage, champion battery, nothing untoward. Low mileage though: only just past 70K km's.
    What do they say though, waiting for the other shoe to drop?
  15. bisco
    52,274
    and it may all be due to how you drive it and take good care. buying used, it's an unknown.
    #15 bisco, Sep 12, 2017
  16. ETC(SS)
    7,309
    For $7k, I would not get into any hybrid that's already 60-75-percent through it's service life.....especially if you're thinking about financing this car, and especially especially if you do not do all of the maintenance and many of the repairs on your cars at present.
    Even over on the left coast.
    Also....if 7k represents your "all in" budget, I'd steer away from up-optioned cars (pun almost unintended.)
    You need to be spending more money on reliability and less on things like seating surfaces and electronics.
    $7,000 can buy a car with a lot fewer miles on the odometer, and without multi-thousand-dollar items like inverters, regenerative braking systems, and traction batteries that Priuses cannot be driven without.
    Add to all of this:
    California has weird things like emissions testing, and laws concerning which catalytic converters can and cannot be put into a car.
    It's not unheard of that a car with nearly lunar mileage can have difficulty passing these tests......in addition to remaining reliable.
    Since, I'm not thusly encumbered I cannot say for sure, but I'm thinking that since hybrids are yesterday's green cars, that they will soon be or already are subject to being sniff-tested.
    More $$$ for the uninitiated.
    Good Luck!
    mjoo and PRI6080 like this.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    If I were to step back and plug those parameters into ANY used car vehicle purchase, and I came back with $7000 for a 7+ year old vehicle with over 200,000 miles on it? I'd probably conclude I'm paying too much.
    It's not so much either the age, or even necessarily the miles, but if I'm dishing out 7 grand for a vehicle of that age and mileage, I want the description to be "excellent condition" for it's age and mileage, not just "good" condition.
    I don't know what the OP's budget is, but I think if you have the time and patience a better deal could probably be found.
    And a baseline I give as a recommendation for anyone investing into an older Prius, is have the "budget" or money available to replace the Hybrid Battery if it becomes necessary.
    You never know....but obviously a failed or dead Hybrid Battery transforms The Prius into a nice driveway ornament. I'd want the money available or set aside for that "possible" eventuality, even if you go years without needing it.
  18. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Kinda like when buying an used Acura/Honda vehicle at 165k miles, no matter how much the price is, set aside $3000+ for an automatic transmission replacement if the previous owner hasnt replace the tranny yet.
  19. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    To be blunt about it, no car with that many miles should be purchased as a daily driver...especially a hybrid. If $7,000 is your budget, buy a low/er miles Corolla or Civic without requiring all the buzzers and whistles. Reliable transportation is the goal with limited funds and both of those fit the bill.
  20. Joaquim Silva
    Joaquim Silva Junior Member
    31
    30
    Lake Havasu City AZ
    You should get a 2012 or 2013 for this price with 200k miles. Ask if and when EV battery was replaced. Very few cars reach 200K with original battery. Prius is more reliable than most non-hybrid cars. That said, you should be prepared for any maintenance if needed.
