Water leaking no A/C
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Alaxamber, Sep 8, 2017.
  1. Alaxamber
    Alaxamber New Member
    Wa
    So, I have had my 2011 for nearly 4 years and this summer I have started to notice a puddle has formed under my car after work. Washington has been rather hot, but today I didn't use my A/C just had it on air flow. I checked the puddle but it was just water. I had my oil change last week and they said there where no leaks...
    Any ideas?
    52,189
    welcome!
    condensation from a/c always leaves a puddle under the car.
  3. Alaxamber
    Wa
    But I do not have my A/C running. Would just having the air flow on LO do it?
  4. JC91006
    JC91006 Senior Member
    16,800
    8,589
    Don't use the airflow and see if there's still a puddle
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Sounds like moisture condensation from using the AC, all cars do this. I freaked out too when my friends truck did that also thinking were gonna be stranded.
    Just like when you spray air out of compressed air dust can and hold the nozzle for a while. Moisture and or frost like stuff will form on surface side of dust can.
  6. bisco
    52,189
    gotcha, i was confused by the o/p. maybe it's excess. see if it continues.
  7. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    If the light next to the "A/C" is on, then the AC is on. It doesn't matter what airflow speed or direction is set at. That puddle would be the condensation from the AC. There shouldn't be a puddle if the light next to the "A/C" is off.
    Raytheeagle likes this.
  8. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Although if you have your control set to windshield defog/defrost, and turn on the fan, the AC compressor will cycle to dry the blown air . . .
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,064
    545
    Tucson, AZ
    2021 Prius
    I would recommend locating the exact source. If it turns out to be under the evaporator box drain, maybe the drain is plugged and taking several days to empty. How is the humidity up there in WA? I know it has been a dry summer for most of the area. The higher your outside humidity, the more condensation will accumulate in the E-box when you have the A/C set to outside air. Any odors?
  10. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Good call, that's got to be it.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I don't think it is possible to shut off the air flow completely.
    I also don't think that it is possible to completely shut off the A/C as it also dehumidifies and helps with keeping condensation off the inside of the windows.
    Safety considerations.
