Getting diagnostic codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nat724, Sep 7, 2017.
  1. nat724
    nat724 Junior Member
    I'm sure this has been asked before, but I can't find the answer. A few days ago, as I was transitioning from a paved to dirt road, all of my warning lights came on. I drove it another mile and called AAA to see if they could come run a code. Long story short, they couldn't. I decided to just drive it to the closest shop (about 20 miles) and got the code run, but it was just 1121, which I'm not too worried about.
    The red triangle is still on, but all the others have turned off. The check engine still comes on sporadically as it always has (because of the P1121 code). I've been reading that I have to take it to a dealer and have then run it there for the hybrid system.
    Is there anywhere else to do this, or just the dealer? I'm hoping to find somewhere a bit cheaper.
    I'm not willing to invest much into this car at this point. It's worth at most 3k, and I'm just hoping it'll last through graduate school. It's the longest I've ever owned a car, and I've definitely abused it, driving through the rocky mountains to ski every weekend and down some pretty bad roads to get to climbing areas. Frankly, I'm impressed that I've been able to get 90k miles out of it (almost 200k total now) given the conditions I've driven it!
    51,791
    what is it, did i miss it in your post?
  3. Prodigyplace
    12,516
    11,739
    Central Virginia
    Their profile says other non hybrid. That should narrow it down a bit. :D
  4. bisco
    51,791
    that's what i was afraid of.(n)
  5. JC91006
    JC91006 Senior Member
    16,759
    8,562
    You need to get a code reader that can read prius codes. The P1121 won't cause the triangle to come on, that would just cause the check engine light to come on.
    A possible failure would be your inverter pump, which is quite common on the gen 2. They fail about every 100k miles.
  6. nat724
    Haha sorry, 2005 Prius.
  7. nat724
    Do you know where I can get a code reader that can read prius codes?
  8. JC91006
    16,759
    8,562
    A favorite here would be the mini VCI with techstream software. it runs off a laptop computer and it'll cost around $25 on Amazon.
  9. nat724
    Is that pretty easy to use? And will do codes for the hybrid system?
  10. JC91006
    16,759
    8,562
    Yes
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    Or download the android Torque Pro app and buy a Bluetooth Elm 327 OBDII reader from Amazon.
    Less than $30 total.
    Read and clear codes. Even hybrid stuff.
    Not as comprehensive as techstream with minivci, but quick for on the go checking and cleaning up of codes.
