Beep Beep Beep Whats that? Whats that?
Discussion in 'Knowledge Base Articles Discussion' started by grasshopper, Jul 8, 2006.
  1. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    Can anyone tell me how to disable the passenger side seatbelt beep? When my dog gets restless while riding, it sets off the seatbelt beep. If it isn't possible then I can engage the belt. Unfortunately, I don't think about it until it goes off. Of course, that’s when we are traveling along in traffic. Then I’m looking all around trying to figure out what is wrong with the car. :eek:
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
  3. clarkeb
    clarkeb New Member
    27
    You could jam something into the little slot that the seatbelt goes in.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ick, that must be one of those exciting unadvertised new "features" of the '06. I just get an idiot light on the dash when the px seat has unbuckled-in weight in it, but no beeping.
  5. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(efusco @ Jul 8 2006, 03:38 PM) [snapback]283096[/snapback]</div>
    Yes, I feel sooo much better that Toyota's lawyers are on the job, making sure I'm safe and protected and only use my accessories in the Toyota approved manor. :angry:
  6. marjam
    marjam Member
    220
    Silver Spring, MD
    The default setting from the factory is that the driver's side beeps and the passenger side doesn't. Someone set yours wrong. In other links you will find how to disable the back up beep and the seatbelt beep. It is simple but takes three hands to do the passenger side. Maybe the dog can lend a paw!
  7. Lil Mo
    Lil Mo New Member
    171
    <div class='quotetop'>QUOTE(marjam @ Jul 8 2006, 09:07 PM) [snapback]283214[/snapback]</div>
    Is that true for 2006? Mine also beeps to encourage my wife to put on her seatbelt. :)
  8. savaged
    savaged New Member
    <div class='quotetop'>QUOTE(Lil Mo @ Jul 9 2006, 09:56 AM) [snapback]283300[/snapback]</div>
    My 06 beeps for the passenger side as well.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Post 13 under this topic has pretty good directions for turning it off:
    http://priuschat.com/index.php?showtopic=18311&hl=seatbelt
    It is the same as turning off the reverse beep except you buckle/unbuckle the appropriate seat belt vice selecting reverse/park. It reportedly works on the 06 just as it does on the 04 and 05.
    My dog refuses to wear a seatbelt also.
  10. champ
    champ New Member
    Southern Gulf Ilsands, British Columbia
    Make sure the passenger seat is occupied when you perform the buckle-unbuckle operation.
  11. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 8 2006, 09:29 PM) [snapback]283160[/snapback]</div>
    Thanks, as usual you have given me just what I needed. :D B)
  12. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(champ @ Jul 9 2006, 11:00 AM) [snapback]283328[/snapback]</div>
    Really? You sure? I thought I read somewhere that the passenger seat had to be unoccupied.
  13. jbarnhart
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(grasshopper @ Jul 9 2006, 09:35 AM) [snapback]283362[/snapback]</div>
    Hee hee!
    What you don't know about Aibos (my robot pals) is that they DON'T obey well at all. They have their own personalities and often wave you off with a "talk to the paw" gesture while they do what they want. It's one of their more endearing characteristics. They can understand what you say perfectly well, but they often choose to disobey you. Just like "real" dogs.
  14. tumbleweed
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(Betelgeuse @ Jul 9 2006, 10:44 AM) [snapback]283392[/snapback]</div>
    Yes UNoccupied is correct.
  15. Anubis
    Anubis New Member
    35
    <div class='quotetop'>QUOTE(tumbleweed @ Jul 9 2006, 11:33 PM) [snapback]283689[/snapback]</div>
    Really? When I disabled all my beeps (reverse & both seat belts), I read that the passenger seat needed to be occupied. When my 190 lb. brother helped me by sitting in the passenger seat and buckling/unbuckling when I told him to, it worked perfectly, the first time.
    This is on my 2006 Prius.
