AC Compressor not turning on
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by eightyHD, Sep 14, 2017.
  1. eightyHD
    eightyHD New Member
    AZ
    2012 Prius V Wagon
    Everything was fine yesterday.
    Did an oil change and topped off with coolant on the passenger/driver side.
    Passenger side was a bit over filled, ran air compressor and rag and blew some out.
    My AC is not cold, nor do i hear the AC compressor turning over.
    BEER MONEY for anyone that can help me resolve this issue.
    I live in AZ and its HOT!!
  2. eightyHD
    eightyHD New Member
    AZ
    i also washed it with degreaser and water hose
  3. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Check, disconnect, inspect, clean and dry electrical connections at the compressor. Degreaser can serve as an insulator.
  4. eightyHD
    eightyHD New Member
    AZ
    THANK YOU!
    I just found the video and performed it and it works!
    icyrius, Air_Boss and bisco like this.
  5. Qwer
    Qwer Junior Member
    2014 Prius v wagon
    #5 Qwer, May 15, 2018
