Gravel road driving in Colorado
Discussion in 'Gen 4 Prius Main Forum' started by LisaHaas, Sep 14, 2017.
  1. LisaHaas
    LisaHaas New Member
    Colorado
    I would like to know any thoughts on driving on gravel roads. I feel like I'm beating the heck out of my 2016 Prius. I have about 20 miles of my drive each day on gravel roads in the mountains. There's no problem getting up and down, but I want my car to last a long time. Sometimes the roads get "wash boarding effect" I drive about 20-25 mph, sometimes slower. Is this killing my car over time? Am I shaking everything loose under the hood? Thanks for any thoughts.
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Good question and I'm no expert on this, being new to the Prius, but I'd think with the reputation built up over the years and applauded loudly on the pages,a Toyota is probably better than most for surviving. Just you wait, there'll be many more answers coming your way soon enough.
    That said, my welcome to Prius Chat comes from UK, about 7 hours ahead of you. (y)
    LisaHaas likes this.
  3. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I live in Colorado and drive mostly on pavement but occasionally on dirt to trailheads. I've got 80,000 miles on my 8 year old gen 3 and it still rides and handles well. In contrast, our 9 year old Nissan Murano (with fewer miles than the Prius) had failure of all 4 shocks and continues to handle poorly after replacement. You might eventually tear up the plastic under-cladding from rocks/pebbles being kicked up. It is not a huge deal to replace it. Some people don't replace it if it comes off, but with your driving on dirt so much, I'd check once in a while to make sure that the cladding is in place and not damaged.
    LisaHaas and tucatz like this.
  4. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    Obviously, any mechanical assembly that's exposed to heavy vibration and higher than normal force cycling will likely result in premature failure. I have to believe that the engineers at Toyota did their due diligence in testing their designs for reliability, but in the end only so much can be expected. I would guess that your suspension components may be the first area to watch, although any part of the car may see earlier than normal issues.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Likely that the suspension and under-body will suffer some as opposed to driving on concrete.
    BUT........
    What's your alternative ?
    If there is no alternative, then be careful and don't worry about it.
    Every time you have the tires rotated ask them to inspect all of the under car components too.
    LisaHaas, RCO and pilotgrrl like this.
  6. jtv
    jtv /* No comment */
    26
    22
    Finland
    2012 Prius+ MPV
    I would recommend installing mudflaps to protect the rocker panels from flying stones/pebbles.
    LisaHaas, bisco and RCO like this.
  7. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    LisaHaas, tucatz, RCO and 1 other person like this.
  8. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Does your dashboard rattle?
  9. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    I abused my 2010 gen 3 driving on gravel roads, and never had any problems. Flashback- shortly after buying the car in 2009 I drove it up a (bad) frontage road on the King River in Sequoia Narional Park with 4 passengers and camping gear. The car kept bottoming out. At times I had everyone out of the car to walk along the road. Prius made it on this trip just fine and I drove it another 100,000 miles no issues at all.
    LisaHaas and RCO like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    But OP has a Gen 4 and yours was a Gen 3.
  11. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Aftermath of a Colorado gravel road last week. Oddly enough the rain and snow in Rocky Mountain national park cleaned 80% of it off two hours later.
    LisaHaas and pilotgrrl like this.
  12. Prodigyplace
    12,625
    11,807
    Central Virginia
    Do you still have your 2011? It may be time to update your Profile.
    RCO likes this.
  13. Yippeekyaa
    137
    160
    North Carolina
    Still have it yes.
  14. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Now, where's that picture of the Monster Truck Prius when you need it?
  15. Prodigyplace
    12,625
    11,807
    Central Virginia
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Gravel roads are no problem. Rock roads no problem. Roads that cross rivers, also doable. You could say we've taken the Prius to places Toyota would have never imagined. And it has performed flawlessly. Nice narrow wheelbase compared to most 4x4's like SUVs means you don't need all the ground clearance because you aren't driving in a rut with a high center. You can drive off-center and escape most obstacles.
    LisaHaas, pilotgrrl and Yippeekyaa like this.
  17. Prodigyplace
    12,625
    11,807
    Central Virginia
    Just for you :D
    LisaHaas, jtv, RCO and 2 others like this.
  18. Prodigyplace
    12,625
    11,807
    Central Virginia
    Or maybe this,
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I prefer the Mr. Fusion Upgrade. Gravel roads aren't a problem then
    pilotgrrl and Prodigyplace like this.
  20. Yippeekyaa
    137
    160
    North Carolina
    Well, I did do this today with my Prius. Had to unhook the small trailer in the second photo to pull the stump to the burn pile too.
    LisaHaas, pilotgrrl and Prodigyplace like this.
