Confirmed: iPhone Qi case that works with Prime's charging pad
Discussion in 'Prime Audio, Electronics, and Infotainment' started by mercat68, Aug 30, 2017.
  1. mercat68
    mercat68 Active Member
    302
    216
    Mount Airy, MD
    Stopped by my dealership this past weekend for touch-up paint and noticed they sell a Qi-compatible iPhone 6/6s/7 case by MobilePal (www.imobilepal.com) at the parts counter. I've been looking for a case to use in the Prime, but mixed reviews and not much consensus on which cases(s) actually work. Given that my Toyota dealer was selling the MobilePal case, I took that as a pretty good endorsement, so I ordered one from Amazon ($19.99 vs. $59 at dealer). Showed up yesterday. Happy to report it worked perfectly the first time out - phone went from 73% charge to 85% after only about 10 minutes on the Prime's Qi pad.
    The case quality appears decent and the fit is good. Also, no overheating issues (a complaint I see in a lot of Qi case reviews). MobilePal also makes a case for the 6/6s Plus, but I'm guessing the Plus is too big to lay flat on the charging pad.
    Case part no. is MP-QWIP7 and here's a link for it on Amazon (one of multiple colors):
  2. Andy Chapman
    Andy Chapman New Member
    South Salem, NY
    I was looking at this case also however I saw a ton of reviews showing how theirs quit after one, two three months and am a little gunshy now of getting one. Might wait to see how you fare with yours.
  3. mercat68
    302
    216
    Mount Airy, MD
    Sure, I understand. Saw the same reviews, but also found "mine died" complaints for every case available, it seemed like. Happy to update the group over the next few months. I am concerned about the small plug from the case into the lightening port on the phone. It's connected to the case with a small ribbon cable that doesn't look like it can take a lot of removal/replacement cycles. I've been successful so far not removing it (other than once to sync some files).
  4. westy72658
    westy72658 Jim Coleman Toyota in Bethesda, Maryland
    110
    67
    Louisa, KY
    Can I get an update on your case? Is it still working to your satisfaction?
  5. mercat68
    302
    216
    Mount Airy, MD
    I upgraded to an iPhone 8 a few months after getting the case and stopped using it because the 8 has built-in wireless charging, It did work flawlessly until that point. But whether the connector on it would have held up to long-term use, I can’t tell you - sorry.
    westy72658 likes this.
  6. westy72658
    110
    67
    Louisa, KY
    Ok thanks for the update.
  7. CraftyCoder
    CraftyCoder Member
    48
    65
    Washougal, WA
    2018 Prius Prime
  8. bill188
    bill188 Junior Member
    Aurora, Colorado. USA
  9. Mark57
    2,945
    2,736
    OK
    I use a RhinoShield CrashGuard Bumper case on my S6 and it works perfectly with the vehicle and other Qi chargers.
  10. benagi
    benagi Active Member
    525
    280
    Utah
    Crafty, I just went to your link. Didn’t know they had an aftermarket case for the iPhone 6 that you can use in the Prime for wireless charging. I have the 6 plus. Looks like I will order a case tomorrow. Thx for the info.
  11. benagi
    525
    280
    Utah
    Is anyone using the QI charger in their Prime with an after market case for the iPhone 6 Plus. I read something in one of the reviews that the plus sized iPhones may be to large for the QI charger.
