So I am told my rears springs are broken...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by preludedude, Mar 20, 2013.
  1. uart
    uart Senior Member
    4,220
    1,210
    Australia
    double post
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    With my cars it wasn't noticeable at all (the last 6" of the bottom coil in each case). But I reached in and found the loose piece just sitting there on the spring seat.
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
  4. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    I have the same problem, one cracked rear spring. I was quoted $550 to replace both by a reputable local mechanic this week. The dealer quoted me $213 to replace one spring. The dealer is less!
    It sounds like this should be no more than one hour of labor to replace both. Or I could borrow some jack stands...
  5. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    It's fairly straight forward R&R, just a lot of interior disassembly/reassembly to get to the strut mount nuts and bolt. Easiest would be to replace the entire strut assembly with something like a Monroe Quick Strut, no hazards/dangers in swapping the springs just bolt-on and go. Rear struts are about a buck-twenty at Rock Auto as an example.
