saving EV till later
Discussion in 'Prime Fuel Economy & EV Range' started by priuscatprimeguy, Sep 16, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I'm trying to figure out how to save all of my charged up EV (about 32.6 miles EV) for the National Electric Car show that's 54.7 miles away from where I live. A while back I selected HV on the EV/HV button but while driving the car continued to eat away at my EV miles. Can I really save all my EV for later or is that just a pipe dream?
    51,804
    try charging up, warming up the car, then plugging in again. see how many miles it eats in hv mode with a warm engine.
    priuscatprimeguy likes this.
  3. priuscatprimeguy
    2,730
    2,640
    so...you don't know:whistle: let's hear from actual Prime owners please:D
  4. bisco
    51,804
    nah, i'm always guessing.:oops:
  5. priuscatprimeguy
    2,730
    2,640
    :cry::cry::cry:
  6. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Bisco makes a good point. There is not a lot of solid info on the Prime yet. Try it and let us know. Most of what I see is from either the PIP or earlier generations of the hatchback. The real concept is to maximize mileage, which may or may not mean maximizing EV. Somebody must be getting 1000 mile tanks, but I don't see them here.
    priuscatprimeguy and bisco like this.
  7. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    On a few long road trips, I've switched to HV mode at startup to preserve the EV battery. It saved about 90% of the range indicated on the EV range display. It would fluctuate up and down a couple of miles but stay within 2-3 miles of the original EV estimate. The EV range indicated at startup was around 32-33 miles. I could drive hundreds of miles in HV mode and still have 29-32 EV miles remaining.
    I wanted to preserve the EV mileage in case of an emergency: such as long blockages on the road due to accidents, stranding in a snow storm or inability to find an open gas station in the middle of the night, etc.
    I thought of saving the EV mileage like someone who would keep an extra gallon of gas in the trunk for emergencies.
    #7 ems2158, Sep 16, 2017
    huskers and priuscatprimeguy like this.
  8. bisco
    51,804
    and i don't think you can force charge beyond 80%?
  9. ems2158
    221
    162
    Bucks County, PA
    That is correct. I tried the HV charge mode, it would only charge to 80%, about 25-26 miles EV range.
  10. priuscatprimeguy
    2,730
    2,640
    Yeah, force charge is ok but very inefficient, my goal is to save EV that is "off the wall" sort of speak:p
  11. bisco
    51,804
    of course, but no one at the swap meet is going to know that. and force charge may be an interesting feature for some people.
  12. priuscatprimeguy
    2,730
    2,640
    Currently I have about 1800 miles since last fill up and I still have a full tank of gas.
    Mark57 and bisco like this.
  13. bisco
    51,804
    maybe you should siphon some off.
  14. priuscatprimeguy
    2,730
    2,640
    good point, but it's SOOO hard to use gas:p
  15. Bombtrack
    Bombtrack Junior Member
    Chicago, IL
    I'm at 1200 miles (from dealer), I still don't know what my gas cap looks like.
    I haven't filled up (3/8 tank) , because I don't want to drag around gas lbs since I'm not using them...
  16. priuscatprimeguy
    2,730
    2,640
    it's located around in back on the driver's side:coffee:
  17. Bombtrack
    Chicago, IL
    It was meant as a joke (as in I don't need to fill up, therefore I don't have to look at my gas cap)
  18. priuscatprimeguy
    2,730
    2,640
    apparently sarcasm is not your best suit:rolleyes:
  19. bisco
    51,804
    har har.:p
  20. I wonder though, if the gas sits in there for that long (how many months has it been?), that if it's E10, water will start to collect, and some of that fuel may break down a bit or affect the fuel system. Although I read that it's a pressurized fuel system (manual page 357), so maybe that is meant to eliminate water adsorption. But I saw in the manual, page 96:
    Have you seen that yet?
