Wheels
Discussion in 'Gen 2 Prius Technical Discussion' started by Coopers ST, Sep 16, 2017.
  1. Coopers ST
    Coopers ST Junior Member
    51
    Colorado
    I want to get a second set of winter wheels. What other cars have people had luck finding inexpensive wheels that fit without rubbing, and the correct hub and offset size?
  2. Mendel Leisk
    41,925
    This is what I'm using for a third gen, might be the same requirement as second gen, as far as the rims:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
  3. Coopers ST
    51
    Colorado
    Will a 16" wheel with a center bore of 57 and a offset of 52 fit? They are a 5x100 bolt pattern.
