The "Next-Generation" Toyota Prius (2008-2009)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DerekLarsson, Jul 7, 2006.
  1. DerekLarsson
    DerekLarsson New Member
    AutoExpress UK reported that Toyota is planning on coming out
    with a "next-generation" Prius that will get approx. 90 usa-MPG
    using lithium ion cells sometime perhaps as early as late-2008
    (it would be a "2009" model). link: http://www.autoexpress.co.uk/news/autoexpr...its_113mpg.html
    This story appeared in the AutoExpress UK once and there have
    been a few other Auto-related blogs that have made reference
    to that same one report as well.
    However, I have not seen this story corroborated by any
    actual second or third reports confirming the story.
    Perhaps Toyota is keeping this pretty hush-hush because they
    do not want to disrupt the current model sales before the new version
    is ready.
    But I wanted to see if anyone here knew of any additional details
    or additional reports about the new Prius plans and whether Toyota
    is really going to follow through and have it ready by year 2008.
    Also, would they make a USA version the same time as a UK version
    and have it to market then-?
    Any genuine info on this subject would be useful ...
    Thanks...
    - Derek
  2. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    The milage figures quoted by Toyota are for a Japanese fuel economy test. The current Prius gets something like 90mpg on that test, so don't get TOO excited about seeing numbers like "113mpg". Still, it will have better economy and higher performance -- it will be a very worthy successor to the current generation.
  3. Tideland Prius
    16,539
    Not to mention 113 mpg imperial
  4. burritos
    burritos Senior Member
    4,946
    252
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 7 2006, 08:00 PM) [snapback]282787[/snapback]</div>
    Wonder if it's going to be more expensive. If not there's going to be some buyers remorse going around.
  5. jbarnhart
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(burritos @ Jul 8 2006, 04:03 PM) [snapback]283104[/snapback]</div>
    Not for those who upgrade! ;)
  6. DerekLarsson
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 7 2006, 09:00 PM) [snapback]282787[/snapback]</div>
    The point was made clear in the article (from April) that the 113MPG was
    not based on USA standards -- and that the equivalent fuel economy for
    this new Model based on USA standards would be about 94MPG-usa.
    So, that's why I referred to it as "approx. 90MPG".
    So, the issue here is not the actual MPG rating itself .. (the article
    provided the USA conversion for us) -- but rather, I am
    looking for more corroboration, more additional reports, or additional
    details about when Toyota will actually produce this Model for
    the USA Market.
    Is this just a speculative article -- or is this really happening and when-?
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Right now nobody knows....well, somebody does, but noone that's allowed to say it publicly.
    The source for that story is a question-mark. Nothing official has been released. If/when it is you'll see it here as soon as anywhere, rest assured on that.
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  9. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Is that a 25% increase?
  10. jbarnhart
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(DerekLarsson @ Jul 8 2006, 08:51 PM) [snapback]283208[/snapback]</div>
    You're not reading carefully.
    The milage for TODAY'S Prius -- i.e. the one in my garage now -- tested in the same Japanese fuel-economy test, is about 90 mpg. Sure, the next one will be better. Maybe even 15% better (although that's a stretch). But don't expect any EPA test showing the new Prius getting anywhere close to 90 mpg.
  11. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 8 2006, 09:25 PM) [snapback]283158[/snapback]</div>
    Yea, hanging on for the 2014 Prius may not be such a great plan by then... <_<
  12. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 11 2006, 12:41 AM) [snapback]284305[/snapback]</div>
    Argh. That's a bummer. I was relly hoping they would nump the MPG substantially for the next model. I guess this doesn't inlude the plug-in feature which is hard to account for?
    From what I've read they are including a larger ICE :-( and it will have better zip (not needed i.m.o) so getting that and maintaining the FE isn't bad. Just not as impressive as I'm hoping. I think I'm back looking at EV's again
  13. Subversive
    Subversive New Member
    251
    <div class='quotetop'>QUOTE(SomervillePrius @ Jul 11 2006, 11:34 AM) [snapback]284424[/snapback]</div>
    Something I have wondered is whether a larger ICE would allow the Prius to improve its mileage while accelerating or traveling at faster speeds (or conversely, whether the tiny size of its current ICE is partly responsible for the mileage hit taken when accelerating or traveling at freeway speeds).
  14. Cheap!
    Cheap! New Member
    1,157
    I hope we can get an expandable battery pack. Maybe you could plug in a 20 mile range at a time and get a Prius 20, Prius 40, or even a Prius 60.
  15. clett
    clett New Member
    537
    Scotland
    <div class='quotetop'>QUOTE(Cheap! @ Jul 12 2006, 09:23 PM) [snapback]285369[/snapback]</div>
    A senior Toyota engineer has said that the next Prius should be a Prius 9.
    (9 mile plug-in capability)
  16. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(clett @ Jul 13 2006, 03:23 AM) [snapback]285520[/snapback]</div>
    Man, I need to change schools. The one I work at now is 11 miles away, mostly freeway. They're building a new one in the neighborhood. It will be 1 mile away. I could do it all on battery. If I had a plug in...whoo hoo. Maybe by the time the 2009 is available I'll be working there. They open in Fall 2007.
  17. DerekLarsson
    Actually, I posted the wrong article (didn't have all the information)
    Please read this article at: http://www.leftlanenews.com/2006/06/06/nex...achieve-94-mpg/
    This is what I am trying to corroborate somehow!
    <div class='quotetop'>QUOTE(DerekLarsson @ Jul 20 2006, 12:27 AM) [snapback]289192[/snapback]</div>
    Also see this article: http://www.leftlanenews.com/2006/04/10/nex...-offer-113-mpg/
    Note that all of these stories point back to the same source: AutoExpress (a U.K. Magazine)
  18. SoopahMan
    SoopahMan Member
    118
    As an existing Prius owner my interest in the next Prius is:
    1) Because I'm a tech geek. I love reading about great possibilities being accomplished.
    2) Because if the new Prius gets 75mpg and the one after it gets 100mpg, it moves the breaking point for more and more buyers where they can't justify buying a clunky old gas burner anymore - even if it's cost alone. Toyota's successes here in R&D lead to a better environment.
    3) If by some disaster I lose my current car, it'd be nice to upgrade.
    I'm not curious so that I can buy one in the most likely scenario that my current Prius lasts though - it's not worth the money to move up every time. Most likely this car will last me 15 years at which point I'll buy a Tesla or something along those lines. But the technology is fun to read about and good for the planet.
  19. glassguy
    glassguy Junior Member
    Rattlesnake CO
    <div class='quotetop'>QUOTE(jbarnhart @ Jul 10 2006, 11:41 PM) [snapback]284305[/snapback]</div>
    I beg to differ. If the AutoExpress article is correct, the US mileage may actually be close to 94 MPG.
    The article states that Toyota's mileage "target" is 40 km/liter. That works out to 94 miles/US gallon, or 113 miles/Imp gallon.
    Cheers!
  20. donee
    donee New Member
    2,956
    198
    Chicagoland
    <div class='quotetop'>QUOTE(Subversive @ Jul 12 2006, 09:25 PM) [snapback]285331[/snapback]</div>
    Hi Subversive,
    The bigger engine may just be a stroked-out engine, to allow it to get 20:1 expansion ratio, rather than 13:1. Although, the Corrola is going up to 1.8 liters too, so maybe its not that.
    But I thought I read somewhere that the optimum piston diameter size for fuel efficiency in a car is something like the size found in the typical 2.0 liter I4 engine. Smaller diameter, and too much heat is loss. Not sure what makes a piston too big. Like why not a 3 cylinder 2.0 liter, instead of a 4? Would make the engine shorter and easier to fit in transversly. Might be tough to balance or operate at 6500 rpm. Anybody have any insight on this?
    Additonally, they are adding a turbo-charger, which is probably why highway mileage is going up. One can size the turbo-charger to overcome the pumping losses closely. Bigger, and it just loads the exhaust gas flow, while bringing the intake manifold way over air pressure during highway operation. Thats good for power, but its bad for econonmy.
    They might also offset the crank to reduce engine friction. One can hope. There is enough room behind the present engine.
