Firebrid: The Prius v Powered Hybrid Convertible
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Jul 4, 2017.
  1. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Reminiscing on my birthday. Just found some photos from when I first bought the Firebird in 1979. It still had the dealer's tag on it when I first put it in the garage. BTW, that's my late Dad in the photo, not me. My wife and I got lots of miles and smiles out of the Firebird before I put it away for the "someday" project (now known as the Firebrid Project.) ;)
    Bill the Engineer
    49,796
    let's see... you were 16, so that would make you 54, happy birthday!
  3. Prodigyplace
    Prodigyplace Senior Member
    11,701
    11,321
    Central Virginia
    I just noticed a familiar car model in the background.
    My first car was a 1967 Oldsmobile Cutlass, purchased used. The engine had been (poorly) rebuilt and I got rid of it when it got 200 miles to the quart of oil :eek:
    The engine was 330 cubic inch wth a 4 barrel carburetor. When you pressed the accelerator, you could watch the gas gauge drop. :cry:
    #63 Prodigyplace, Sep 21, 2017
    m.wynn and Bill the Engineer like this.
  4. Bill the Engineer
    1,048
    2,278
    467
    Nice try. I bought the Firebird when I graduated from College. I just turned 60.
    My dad got tired of the hi-test gas and oil consumption with his, so he dropped a regular gas Pontiac 350 into it. The car ran great for years after that.
    m.wynn, bisco and Prodigyplace like this.
  5. Bill the Engineer
    1,048
    2,278
    467
    95F outside and humid. Too hot to work in the garage. Maybe tomorrow...
    breakfast and Prodigyplace like this.
  6. bisco
    49,796
    you're showing your age.:cool:
  7. Prodigyplace
    11,701
    11,321
    Central Virginia
    You need that new air-conditioned garage you have been designing.
    Bill the Engineer likes this.
  8. Bill the Engineer
    1,048
    2,278
    467
    Every day, my friend. Every day.
    Considering the a/c went out at home two days ago, I wasn't able to cool off until they finished installing the entirely new system this afternoon. ($$$ OUCH!)
    Two more years...
    Bill the
    bisco, Raytheeagle and Prodigyplace like this.
  9. bisco
    49,796
    that's my big fear, a/cgoes out in july, no one came come for two weeks, and when they do, it's top dollar. sometimes i think it would be wise to make a preemptive strike.
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,483
    Bay Area, California
    2019 Prius Prime
    How olds your system? When we bought our current house, the system was 22 years old and you could hear it running on the opposite end of the house:eek:.
    Replaced the unit as the repair cost would have been 25% of a new unit.
    +1 for a pre-emptive strike(y).
  11. bisco
    49,796
    mine is finishing its 10th summer. i've read that's the lifespan?
  12. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    That's what is quoted. Depends on many factors. But if not giving any problems and is serviced regularly, you can probably stretch it out.
  13. bisco
    49,796
    never serviced, what can i do besides changing the filter? i actually asked my oil company, who instlalls and services a/c, when they sent me a $99. tune up special, the filter was all they do.(n)
  14. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    A filter is one thing you can do and much cheaper than $99;). Seems like they took advantage of you:(.
    What I also do is inspect the system for damage particularly the outdoor coil. Ours is on the east side of the house and not near any potential damage (rock from a lawn mower as an example). I also clean the coils to ensure good heat transfer;). If you have a very efficient system, it's worth also ensuring the condenser drain is clear. Our unit is on the second floor and if the drain is clogged, it could rain down from above. Happened to the inlaws house a couple of years back.
    Just some other simple things that you can do(y).
  15. bisco
    49,796
    thanks! i have a high speed system, and yes, on the second floor. i will check the drain pan more often. how do you clean the coils?
  16. Raytheeagle
    11,251
    15,483
    2019 Prius Prime
    I take compressed air to the coils every so often (probably twice a year). More important if you live in a dusty area. When we lived in Kansas we were right next to fields that put a fine layer on the coils.
    Think of it as a very large radiator. The dirt will act as an insulator and reduce the efficiency causing the unit to work harder.
    Hope that helps (y).
  17. bisco
    49,796
    will do, thanks!
  18. Prodigyplace
    11,701
    11,321
    Central Virginia
    You might want to make sure you use filters that do not impede the airflow more than necessary. A number of years ago when we got the heat pump at out former house, the technician sold us washable electrostatic filters.
    He called the fine disposable allergy filters we had "heat pump killers". :eek:
  19. bisco
    49,796
    huh, the only filters i see at the depot are paper. i've been using 3m.
  20. Prodigyplace
    11,701
    11,321
    Central Virginia
    We have dust allergies & small dogs. We were buying the better filtering 3M Filtrete one that were the "heat pump killers".
    I cannot remember the brand, but we bought some washable electrostatic filters that restricted air flow less., We vacuumed them about twice a week to clean off the dog hair & dust. They worked well until we sold the house early last year.
