Normal Prius operating temp.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Allannde, Feb 20, 2006.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    just to be on the absolutly safe side of it, leave the bottom 3 inches of the rad not blocked as that is the portion with the inverter cooler. Like Dave said get a CAN-view or Scangauge. For other reasons as well as temps.
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Time for confession. Frank is right! I don't think you can over heat the ICE in the mild climate of the PNW. This is classified as "marine climate" The ocean heat pump goes up to the arctic then comes down to us. In England it is the Gulf stream, here it is the Japanese Current. It tends to cool and moderate our climate. With my radiator blocker I can not get the Prius above 207 or so. In a colder climate, in winter, you are home free. As we get warmer in the spring I hope to watch how things change. With my present set up I can stop and modify the air flow as needed to keep the ICE temps in a narrow range. In the south land the radiator blocker will have a short half life, and further north longer and longer. I wish I could monitor the MG2 and Inverter temps as well.
  3. Frank Hudon
    4,147
    yahoo lips win!
  4. EngMarc
    EngMarc Member
    61
    40
    Pittsburgh, PA
    @hdrygas
    What setup do you have for blocking the radiator?
    I’m in Pennsylvania and I’ve been monitoring my Prius with a very detailed UltraGauge with a lot of custom gauges I created from the scangauge spreadsheet.
    I watch my ICE come on regardless of outside temp, force an engine warm-up and then shut off just to do it all over again in a few miles. I’ve had the dealer ‘check’ the radiator thermostat which they say is ‘ok’ (I’m not so sure).
    I’m a mechanical engineer by training so very comfortable with thermodynamics and heat transfer or should I say thermal engineering. It seems Toyota spent all their money on the hybrid electrical, ECU, toque summing gearbox and autostart technologies and have almost entirely neglected the one component that significantly degrades MPG - engine warm-up. On one assignment, I drove 1-1.5 miles in subzero temps and got a whopping 17 mpg WITH THE HEATER OFF! The prius mandated it run the engine to warm it up despite the fact that I could have driven the whole distance on electrics only. Even with the ‘EV’ switch on, under about 140 degrees engine temp, it mandates a ‘warm-up’ run.
    So, I’m thinking of significantly trying to conserve thermal energy on my Prius 2013 to see if it will improve my winter driving. At this point, I could be driving a gas guzzler in the winter time and get the same mileage.
    Anyone out there with radiator baffles or blockers or whatever to retain some engine heat, I’d love to know what you have and any pos/neg aspects.
    Thanks in advance.
  5. Mendel Leisk
    38,106
    @EngMarc member hdrygas was last on the site in 2008.
    Prodigyplace likes this.
  6. EngMarc
    EngMarc Member
    61
    40
    Pittsburgh, PA
    Ok thanks, any others out there with radiator baffles or something let me know.
  7. Mendel Leisk
    38,106
    Here's some info:
    https://priuschat.com/threads/2010-prius-grill-blocking-strategy.62556/
    I follow a simplified version of the above: block 50% of lower grill below 10C (one 1.5" dia x 4' slitted pipe insulation tube, pushed onto grill slat and secured with velcro straps), and 100% (a second tube), when temps stay consitantly below 0C. I leave the upper grill open. Our winters on the coast are mild; it's not that critical
    One other thing I do, is to push similar pieces of tubing onto the seams at engine bay sides, to close the gap between fender top edge and hood. This was a suggestion by @Ferls80. That I leave in year 'round. That holds the heat in better, and I think has a side benefit of keeping the engine bay more dust-free.
    mjoo likes this.
