Plastic charge port cover issue
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by GT4Prius, Sep 23, 2017.
  1. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    My charge port cover will no longer stay put, in its parked place when the charge port is in use.
    I put it in its parking place and it stays there for a short while, but the design means that the plastic tether is in tension and springs the cap out.
    As well as looking untidy, and annoyingly hitting the car bodywork when it springs out, it then gets the inside of the cover wet if it rains.
    See before and after photos.
    Does anyone else experience this? Note that the European car has a slightly different looking arrangement judging by the Toyota U.S. video about charging the Prime, with the parked cap sitting at 90 degrees from the position used on my car.
    I am wondering what to do about it. Any ideas? Only a niggle I suppose but annoying nevertheless, especially on a car that is only 6 months old.
    I could put some sort of padding in there I guess but that might hold water which would not be good.
    48,980
    does the attachment point on the car swivel?
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,018
    Westminster, Colorado
  4. bisco
    48,980
    that looks like added flexibility would not tend to pull it away.
  5. jungleland1972
    73
    65
    Chesapeake Beach, MD
    Yeah, my cap is similar but the part it docks into is different. Mine is more like this (it's not my pic): [​IMG]
  6. Lee Jay
    5,850
    4,018
    We have ours attached to the right-side to keep it in place during charging.
  7. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Mine is just like your pic.
    Does yours stay put?
    The problem is that the tether is designed so as to work perfectly when it's covering the charge port, but not when it is parked in the right hand space during charging.
    The tether does not swivel in any way at the cap end. Only where it is attached to the car.
    Here is another view of mine.
    Below is the position that the cap tether wants, but the cap parking holder doesn't allow.
    Seems like faulty design to me. Either the tether needs to have a vertically rotating attachment to the cap, or the cap parking place needs to be rotated by 90 degrees clockwise.
    #7 GT4Prius, Sep 25, 2017
  8. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Actually the space to the right of the J-1772 receptacle is for a fast charger plug, which comes on the cars in Japan only.:D
  9. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    I know that Japanese cars have an extra socket, but on non Japanese cars the space is used for parking the charge port cover and there is a receptacle for that purpose.
    priuscatprimeguy likes this.
  10. priuscatprimeguy
    2,730
    2,640
    do you have documentation to support this assertion?
  11. Lee Jay
    5,850
    4,018
    Owner's manual, page 117.
  12. priuscatprimeguy
    2,730
    2,640
    Wow! I checked mine out and it looks like the receptacle that holds the cover is too large to hold the cover on mine, that's what led me to assume that the receptacle was designed for a fast charger connection.:confused:
  13. My plastic charge port cover also slides out easily... except unless I insert the plastic cover oriented at a diagonal, so that the handle part is twisted over pointing 1 o'clock and 7 o'clock. Then it slides in to the space on the right and there it stays put.
  14. priuscatprimeguy
    2,730
    2,640
  15. Lee Jay
    5,850
    4,018
    The dangling one is the cap for the EVSE plug.
  16. priuscatprimeguy
    2,730
    2,640
    ohhhh, dang! I knew that! (facepalm)
  17. Oh that one? That's easy, from page 137, step 5:
    Have a nice charge!
  18. priuscatprimeguy
    2,730
    2,640
    I'm not too good with steps:cry:
  19. Tideland Prius
    16,072
    I've yet to see one person use the hook for the factory EVSE plug cover. All the photos and videos I've seen had them dangling against the paint.
  20. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    The manual says to attach it to the cord
