how do I set the lights for auto-off?
Discussion in 'Gen 4 Prius Main Forum' started by cathinpa, Sep 25, 2017.
  1. cathinpa
    cathinpa New Member
    pennsylvania
    I can't seem to find this--there is not an Auto module on my 2016 Prius 2 but I think they will still go OFF automatically, right? I am scared to play around with this somehow as a newbie. Do I need to set the lights a certain way? thanks for this treasure trove of info.
    cath
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    "Automatic light off system
    When the headlights come on: The headlights and tail lights turn off 30 seconds after a door is opened and closed if the power switch is turned to ACCESSORY mode or turned off. (The lights turn off immediately if [lock] on the key is pressed after all the doors are locked.)
    When only the tail lights come on: The tail lights turn off automatically if the power switch is turned to ACCESSORY mode or turned off and the driver’s door is opened.
    To turn the lights on again, turn the power switch to ON mode, or turn the light switch off once and then back to [headlights on) or [marker lights on]"
    https://www.toyota.com/t3Portal/document/om-s/OM47B39U/pdf/OM47B39U.pdf page 245
    I park in a garage so I do not want the headlights to stay on for 30 seconds. (if I parked on a long driveway I might want them on for 90 seconds) Only you can decide the amount of light you need for safety.
    Page 757 hints that a Dealer or a OBDII programmer may be needed to change the delay on your Prius, unless you have Entune.
    Time elapsed before the headlights turn off default 30 seconds, programmable to 0, 60, or 90 seconds.
    #2 JimboPalmer, Sep 25, 2017
    RCO likes this.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    By your left knee there is a button for the auto-off feature. Turn that on. After that all you have to do is turn the headlights to auto or on and leave it like it is. If you want auto-high beams, click the stalk forward and leave it there.
    When you turn off the car, and walk away, it should take 30 seconds to turn off.
    RCO likes this.
  4. Prodigyplace
    12,708
    11,847
    Central Virginia
    I believe on the Gen 4 Prius 2 the headlights stay on for 30 seconds by default and then turn off as stated above.
    I never waited to test mine. I changed the setting so they so they turn off right away.
    If you mean auto-high beams, therr is a switch on the lower left side of the dashboard.
    Tyfly and RCO like this.
  5. cathinpa
    cathinpa New Member
    pennsylvania
    thank you!!!
    Prodigyplace likes this.
