Rear Bumper Question
Discussion in 'Gen 3 Prius Technical Discussion' started by Malosos, Sep 25, 2017.
  1. Malosos
    Malosos Member
    109
    33
    Los Angeles
    The rear bumper to my 2010 sags a little on the passenger side corner, might need tightening somewhere or maybe something loose, anyone encounter this...see pic. FullSizeRender.jpg
    Burna J likes this.
  2. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Before buying my Prius, I spent 6 months test driving and inspecting gen 3s. The majority of rear bumpers gen 3s are like that, the least were 2012 and up. When I push down on them, it makes a loud pop as if it was broken in an accident.
    Malosos likes this.
  3. Burna J
    1,065
    3,334
    53
    Long Beach, CA.
    That's not bad at all... I've seen much worst. :)
    Malosos likes this.
  4. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I'm guessing the rub mark on the edge of the bumper indicates that a contact with something was probably the cause.
    I would find instructions somewhere to remove and fix it.
    Malosos likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The rear bumper cover is a scuff and scratch magnet. I wouldn't spend a lot of time or money on the corner, just brush on some touch up paint to cover the black plastic.
  6. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Personally I'd leave it alone and keep driving. But if begin to lose sleep, then I'll order item below:
  7. Mendel Leisk
    38,952
    The bumper on ours looks about the same. A minor design fail, when a "bumper" can't keep itself in place.
  8. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Where the bumper meets the rear light, there is that gap that is its widest. Then it narrows as the gap traces toward front of the car.
  9. Malosos
    Malosos Member
    109
    33
    Los Angeles
    Bump...any other suggestions to remedy this?
  10. Mendel Leisk
    38,952
    We got a minor rear corner bump (speaking of bumps), and the body shop managed to tighten it up, which lasted for a few months, but again it's starting to sag, open up the gap. I just kinda ignore it.
    Malosos likes this.
