1 more EV question... Must be at a stop?
Discussion in 'Gen 2 Prius Technical Discussion' started by Rogust, Jul 11, 2006.
  1. Rogust
    Rogust New Member
    28
    I just installed the CoastalTech EV switch (20 minutes...easy instructions) on my '06 #7.
    It seems that I have to be at a stop when I do the 2-second pull on the Cruise stalk to get it into EV mode.
    Anyone else notice that? Am I doing something wrong? :unsure:
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(Rogust @ Jul 11 2006, 06:36 PM) [snapback]284718[/snapback]</div>
    At a stop at the start up, yes, later while driving no if you meet the criteria it will go into EV mode. You will usually not be able to do it just after starting. I most often use it at the end of a trip when I am going home.
  3. Rogust
    Rogust New Member
    28
    Thanks for the info.
  4. K5VMI
    K5VMI New Member
    Baton Rouge, LA
    Agreed. I will usually activate EV when coasting to a stop light or sign. I am also trying the technique of using EV on startup from as many stops as possible. It appears that I am getting about a 2 mpg addition onto my normal mpg cumulative displayed on the MFD.
