Prius body panels..why not make them out of composite
Discussion in 'Gen 2 Prius Main Forum' started by fuelsipper, Jul 10, 2006.
  1. fuelsipper
    fuelsipper New Member
    63
    southern Oregon
    material. I do not know the technical term, but am thinking plastic/kevlar, or some concoction thereof. Maybe that would be too expensive to make. And I just might find out...
    The point is...the body on the Prius is about as sturdy as a can of Hamms Beer (not that I would know how that tastes)
    I could go on with all of the body damage our 2005 Prius has aquired, most in parking lots (yes, we always look for a good spot, it still happens)
    I am wishing for a plastic body, one that pops back into shape. Way past the first dent phase, just wondering if anyone else has had a thought on the subject..
    E-Eric
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    The side panels on my 1996 Saturn SC2 coupe were some sort of plastic. You could pound on them and they would give and bounce back. It was a selling point and after 10 years it didn't have any "dings". I imagine they would make the car lighter. You would need to reformulate the paint so it would be flexible like the panels. The frame was a cage to protect the passengers, much like the Prius.
  3. jtullos
    jtullos New Member
    172
    Dayton, NV
    At present, making composites is neither easy nor cheap. I've done a very small amount of work with composites, and yes, they are lighter and stronger. However, composite production is not yet (to my knowledge) fully automated, certainly not on the scale necessary for a production automobile.
    Composites are not necessarily flexible. Some are, some aren't. It's all in how the composite is put together. What I worked with, and those I've seen, are all for rigid applications (airplane wings, rocket/satellite components, etc). These are all applications where a few pounds can make a huge difference in cost. Launches to orbit typically cost a few thousand dollars per pound, whereas most cars probably won't have a noticeable effect from a few pounds here or there. Now if you can start taking away several hundred pounds (possible with composites, though still expensive), then you start to get a significant effect.
  4. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    It is a great idea...but there has to be some reason that it never really caught on with other vehicles. Maybe a safety issue, maybe an electronics issue (it is hard to wire a car when you can not find a ground because the panels are plastic). It could also be that the repair costs on those panels was too high when compared with metal.
  5. fuelsipper
    63
    southern Oregon
    <div class='quotetop'>QUOTE(Godiva @ Jul 10 2006, 04:51 PM) [snapback]284089[/snapback]</div>
    Hummm...I didn't know that about the Saturn. thank you for the information, and yes the question does arise...why not in other vehicles?
    E-Eric
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If you get enough dings in something that holds its shape, then
    you'll have those aerodynamic surface dimples that'll increase
    your MPG!
    ... when the "golf cart" turns into the "golf ball" ...
    _H*
  7. daniel
    14,487
    1,519
    Spokane, WA
    I don't know. This is just a speculation: It could have to do with crumple zones as a safety factor. A body that takes an impact and then springs back into shape is not absorbing any energy. A body that crumples is absorbing energy. For safety you want the body of the car to absorb energy so that your own body doesn't.
  8. donee
    donee New Member
    2,956
    198
    Chicagoland
    Oops...
  9. Tideland Prius
    16,615
    Plastic panels mean larger gaps between panels which leads to ungainly gaps between panels and aerodynamic issues in that they create larger eddies.
  10. fuelsipper
    63
    southern Oregon
    I have the answer why plastic type flexible body parts are not an industry standard!
    ABAA
    Auto Body Associates of America 8)
  11. McShemp
    McShemp New Member
    371
    SA, TX
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 10 2006, 08:54 PM) [snapback]284195[/snapback]</div>
    What are F1 cars made of (where price is no object)? Composites (not plastic).
    I think the Prius is ground breaking enough. Perhaps the next gen or the next hyper-mile hybrid will add some composite pieces.
  12. jtullos
    jtullos New Member
    172
    Dayton, NV
    <div class='quotetop'>QUOTE(McShemp @ Jul 10 2006, 08:01 PM) [snapback]284247[/snapback]</div>
    Do a google search for aptera hybrid and take a look at some of the results. I'm personally going to remain skeptical until they're in production, but it looks promising.
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    How about using hemp? No, I'm not advocating drug use. I'm thinking of using a renewable, sustainable resource as a substitute for metal. I recall a video, though I can't find it now, of a vehicle made from hemp that resisted the blows of a sledgehammer with minimal damage. Is it BMW that's using hemp for door panels?
  14. Godiva
    10,339
    What is the body of the Tesla made out of?
