Maitanence required
Discussion in 'Gen 4 Prius Main Forum' started by Alex swartzendruber, Oct 8, 2017.
  1. Alex swartzendruber
    Alex swartzendruber New Member
    Iowa
    I have nearly 62k miles on my 2016 Prius II and maintenance required for hybrid battery cooling parts at your dealer. What does this mean I read on line it could be the filter for the cooling fan for the hv battery
    51,814
    welcome!
    i think that's right, check the battery intake cooling grille filters for lint and blockage.
    RCO likes this.
  3. Alex swartzendruber
    Iowa
    I checked the filter and it's all dirty would I need to get a new one?
  4. bisco
    51,814
    no, you can wash it out and let it dry. do you carry animals a lot?
    RCO likes this.
  5. Alex swartzendruber
    Iowa
    No I do not, but I do drive on gravel roads quite often.
  6. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    There's a cabin air filter, do you drive on these gravel roads with the windows down?
    RCO likes this.
  7. Alex swartzendruber
    Iowa
    I do some times but not too often I cleaned out the filter but haven't washed it yet. All is good now no more error message and my mpg have returned back to normal
    Elt31987, RCO and bisco like this.
  8. bisco
    51,814
    any idea what was clogging the filter?
  9. Alex swartzendruber
    Iowa
    Maybe some papers that were in the back seat fell. But, did get quite a bit of debree from the filter.
    RCO likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's a cautionary tale, but always best to keep the cooling vent clear of stuff that might obstruct it...
    .. if you can remember to, that is! (y)
    krmcg and Raytheeagle like this.
  11. jrt6
    jrt6 Junior Member
    31
    Houston, TX
    Thats what I do! If I wash the car, I always vacuum the vents since i'm already vacuuming the interior.
    RCO likes this.
  12. Mendel Leisk
    41,258
    It might be a good idea to check the actual fan. You'll be a bit of a pioneer, if you do. If it's similar to third gen it shouldn't be too hard, just takes a bit of thought and patience. Likely you will not have to completely remove it to clean.
    That's a lot of miles, btw.
    RCO likes this.
  13. 11polo
    11polo New Member
    Corona CA
    2016 Prius has over 100K. No pets and pretty keep it clean but dusty area due to constructions in the area. Got Battery Cooling Part Maintenance Required recently. Replaced, air and cabin filters. Located the intake fan and dust off the fan area w vacuum plus the dirty filter but put back. Just ordered the filter for $16. Now I still see the sign on my dash now can’t reset. Any advice?
