Official Suspension Thread
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Mission Auto, Aug 9, 2016.
  1. hayanxpocho
    hayanxpocho Junior Member
    Honolulu, Hawaii
    Three Touring
    16831160_10210915616822278_4624889067885403980_n.jpg 16864343_10210914187666550_67667499499557749_n.jpg hey im running rsr down springs. is their a way to not bottom out? would coilovers fix this? I heard our cars don't have much travel. could I get lower on coilovers and not bottom out? running rsr springs with 19x9.5.
    Depe and krmcg like this.
  2. Creep808
    Creep808 Junior Member
    Aiea, Hawaii
    Three Touring
    Can anyone chime in on which coilovers setup you think would lower mines the lowest with the smoothest ride? Thanks just pretty much for stance and somewhat handling.
    Depe likes this.
  3. PriusTrhee
    PriusTrhee Junior Member
    When swapping the rear coilovers did you have to remove the entire interior rear quarter panels to access the rear upper coilover mounts? Or do they jus screw out from underneath?
  4. RightOnTime
    RightOnTime Senior Member
    758
    1,628
    183
    Kidnapped in OC, CA
    Toyota finally improved this design! The Coilover mounts can be accessible from underneath the car
    iPhone ?
    sfv41901 likes this.
  5. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    what he said ^^^ (y)
  6. PriusTrhee
    Is there rear upper mount brace for the new ZVW50 Prius?
  7. PriusTrhee
    What's the offset your running on these 19x9.5?
  8. Zwergo
    Zwergo New Member
    herford
    2018 Prius
    Weiß jemand ob ich Tieferlegungsfedern kaufen kann mit Gutachten (Tüv) für Deutschland ? Wichtig ist das sie hinten etwas weniger Tieferlegung haben.
  9. iDealShopper
    iDealShopper Junior Member
    Alhambra, CA
    2018 Prius
    Just wondering, What size are those Tires and Brand, I know those rims are 18's. Thanks
  10. bad shreda
    bad shreda Junior Member
    san diego
    want to add rear sway bar ,any recommendations?
  11. bad shreda
    san diego
    Hey, so was wondering where to start with tightening up rear end on 16 prius, where to go 1st? Rear power braces (cusco) or start with a center and work out?
  12. krmcg
    2,592
    2,390
    Whittier, CA
    I would start with a sway bar and see if I needed any more than that...
    knockknock_2 and bad shreda like this.
  13. h22fastback
    h22fastback Junior Member
    Massachusetts
    Anybody happen to know if the gen4 prius and the prius prime of the same MY share the same suspension?
  14. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    I'm about to get a Gen 4 and will want to reduce body roll. I'd prefer a TRD rear sway to Cusco, for the better stiffness-to-weight ratio of a hollow bar, but TRD doesn't seem to have one yet for Gen 4. Does anyone know whether TRD expects to have one? (I've called them, but didn't reach anyone who knows.)
  15. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    I don’t think they are going to produce one. They did make something pretty amazing for the Gen 4 though. It’s called a motion control bar.
  16. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Thanks 2020XLEAWD! Guess you're right, so I suppose I'll go with either the rear ARB only, or both, from Cusco. If anyone has experience with putting only Cusco's rear bar on the Gen 4, and/or knows whether that might compromise the stability-control system, I'd love to hear of it. And if anyone has tried the motion-control beams that 2020XLEAWD mentioned, that'd be interesting (though they're pricey) too.
    #56 Anthro, Dec 13, 2020
  17. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Thanks Paul--the video was exciting, and you definitely passed that Porsche! Perhaps you could give me some idea what adding only the rear Cusco bar would do. For example, would it noticeably reduce body roll, and might it produce oversteer or interfere with the stability-control system? Last, any downsides to putting on both front & rear, other than cost?
    Thanks, Stewart
    #57 Anthro, Dec 13, 2020
  18. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    I have the rear sway bar and the front strut tower bar from Cusco. The rear bar has really firmed up the rolling on turns and on highways where you’re taking longer sweeping turns. The strut bar is more like a engine bay chasis brace since it doesn’t connect the strut towers. It makes turn ins much sharper. I may get the front sway bar too. Just debating if I should get the motion control bars instead
    Anthro likes this.
  19. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Thanks
    Thanks 2020XLEAWD. Did you feel that having only the rear ARBs produced oversteer, or that it might confuse the stability-control systedm? After you mentioned the motion-control beams, I read TRD's description and looked at their pictures, which indicate that the beams reduce the rate of body roll and lateral forces on the driver, but I don't understand how they do it or how they might relate to sway bars, if at all. I'd appreciate any comments on that.
  20. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Haven’t had problems with oversteer. I switched to michelin crossclimates for the winter and they are very sticky. Here’s the Motion Control Beam video by TRD
    Anthro likes this.
