Is inverter pump always on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by phoebeisis, Oct 9, 2017.
  1. phoebeisis
    phoebeisis Member
    139
    This is a separate sorta' questions
    I think I have an inverter coolant pump failure
    second one-first happened at 55000 miles-now at 111,000 miles
    Three signals RED TRIANGLE CHECK ENGINE AND CAR WITH EXCLAMATION POINT
    Car still runs fine-made it home
    I read that if you hit START twice-no brake
    then a functional pump should be ON
    and it should vibrate enough to vibrate the RESERVOIR HOSE-and reaching down-should be able to feel it vibrate
    I have NO vibration
    and with ICE on-still no pump or reservoir hose vibration
    Is this correct-the pump is on as soon as vehicle ignition is on
    or as soon as ICE on?
    No turbulence in reservoir also
    Thanks
    Charlie
    ps great forum-I always head here for Prius problems-just in 11 years counting this one
    traction battery failure and 1st coolant pump fail
  2. Patrick Wong
    18,200
    6,500
    The inverter coolant pump should run whenever the Prius is IG-ON or READY.
    valde3 likes this.
  3. phoebeisis
    phoebeisis Member
    139
    Patrick-thanks again-pretty sure you helped me before-
    I did the double push on start-no brake pedal
    No vibration on hose or on actual pump
    The plastic shroud lifts up easily-since half the clips weren't reinstalled after perhaps the first pump was replaced
    Yeah dead silent no vibrations dead as a doornail
    Thanks again-debating DIY or dealer
    DIY with bought at dealer pump-maybe $180
    Dealer probably $700-and fighting off their attempts to sell me something else
    but they will do it "better"
    and I won't be near any 25000 watt wires
    Thanks
    Charlie
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Charlie to DIY or let the dealership replace the pump is entirely up to you. Patrick has a great How-To on PC if you decide to go that direction.
  5. phoebeisis
    phoebeisis Member
    139
    M in KC
    Patrick W-
    Thanks-yes it was the inverter-and yep Patricks info is always spot on
    I went with the dealer-$440 total-not bad at all
    Originally they-Lakeside Toyota- quoted $560+ Tax-$610
    but it was $440 Total
    My 31 yo son needed it for a date he has Thursday-and I would have bought the pump online for $110 or so-and it wouldn't have arrived until Thursday-
    And Murphy's Law-always fully in effect the 1st time I do a repair replace
    much less now that I'm older-66-and weaker and more careful-but learning curve and Murphy-
    always a consideration
    and I wanted my son to cough up the $$-motivate him to be more aware of $$ maintenance etc-
    not rely on dad-
    but mostly Murphy and Learning curve and time considerations
    If the difference had been $600 vs $300 I would have DIY
    but just $300 -let pros do it-had good luck with Lakeside Toyota Causeway Blvd Metairie( give credit to good dealers-to OK repairs-and a clutch replacement 1986 Toyota truck in 1994) also so 3 good repairs-no problems-fair price
    It was the Inverter coolant pump-AGAIN-1st failed at 60,000 miles 51,000 miles and 6 years ago
    I debated DIY vs Dealer
    I had Lakeside Toyota do it-$440 all total $250 labor $127 pump-$20 coolant-$40 tax
    VS getting it from Amazon-$110 and 3 days to arrive
    With Murphy's Law fully in effect-meaning some chance
    1)I would break something doing the repair-1st time doing repair-fair chance it would go wrong
    2) some chance it would be thw WRONG REPAIR-no vibration and no turbulence in reservoir-so small chance
    3) tiny chance one of the fasteners would break-or be too difficult to remove
    'All in All I decided to pay another $320 to have Lakeside do it-same day brought in
    Lakeside did the Traction battery replacement-under warranty-no BS extras
    and true to form-not much pressure to get other repairs(some but low key-no it will break and kill you stuff)
    Thanks again-great source of great info
    Charlie
    Raytheeagle likes this.
