I found the missing 4" (vertical) in the trunk. It is below the battery.
Discussion in 'Prime Main Forum (2017-2022)' started by RonMc5, Oct 11, 2017.
  1. RonMc5
    RonMc5 Member
    89
    73
    Santee
    There is a normal looking motorcycle that comes with 6.x KWHs, upgradable to 16KWH in the normal engine gas tank area. (Zero S) The gas tank area is otherwise empty, 'til the upgrade is added. (there are two different sized upgrades, mutually exclusive). I am sure it too needs to be cooled, and there is not engine to help out as it is all electric.
  2. Tideland Prius
    16,604
    3" would make the floor level with the rear bumper lip! Back to where we'd want it to be.
    Mendel Leisk and RonMc5 like this.
  3. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    Maybe the battery that Toyota wanted is behind schedule. The new battery in a couple of years we’ll be four times the power for same size or same power for 1/4 the size.
    I well take twice the power for half the size so I can still charge at home at 220 volts.
    Prius Maximus likes this.
  4. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Huh, I suspected that that packaging was the case, but that's atrocious.
    It is hard to make a form-fitting battery, though, and they almost certainly didn't want to make a new unibody stamping for the Prime. So, this is the solution they came up with.
    I'm going to harp on this again and again, though - a relatively simple shape battery could've fit under the rear seat (and ventilation could work as it does on the Gen 4 Liftback, pulling air from under the seat, with that design), and a complex shape gas tank that goes into the former spare tire well is relatively easy to make. Why didn't they just do that?
    Trollbait, jaqueh and bisco like this.
  5. Prodigyplace
    12,629
    11,808
    Central Virginia
    Two words.
    Ford Pinto.
    One word
    lawsuits.
    jerrymildred and Mark57 like this.
  6. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Didn't stop VW or Hyundai.
    jaqueh likes this.
  7. Prodigyplace
    12,629
    11,808
    Central Virginia
    That just means Toyota is smarter, IMHO.
  8. bisco
    52,286
    i think they didn't do it cause japans solar roof battery got priority.
    Prodigyplace likes this.
  9. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The Golf GTE/Audi A3 sportback e-tron and the Passat GTE have been out for a few years, and there isn't a Pinto-esque scandal. And, with barely any compromise on cargo capacity compared to their ICE-only counterparts, that can help adoption of PHEVs.
    I mean, unless Toyota is trying to weaken the Prime's sales by not making it anywhere near as useful as a standard Prius...
    Also, Toyota's battery layout bothers me more than Volkswagen and Hyundai's fuel tank layout. The Toyota battery is further back in the car, and a Li-ion battery being punctured almost guarantees a fire, whereas a punctured gasoline tank only increases the risk of a fire. (That's not to say that it's a serious concern, but I'd rather have the battery more protected, especially if it ALSO makes it easier to have good cargo space.)
    #69 bhtooefr, Oct 13, 2017
    jaqueh likes this.
  10. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Keep in mind as suggested above the "missing 4-inch" appears to mainly be the indent for the spare tire. The picture I think tends to exaggerate the size of the space in the photo, like holding a small fish on the hook closer to the camera to make it look big.
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    This is a G4 Prius Hatchback. If you imagine laying the battery where the dark gray foam is, I think the gap shown in the OP is mostly the indention for the tire as seen from the back of the car.
    wjtracy and Tideland Prius like this.
  12. hill
    8,898
    no - cooling batteries with just air is potentially a greater heat danger. 6Kw does NOT create a lot of heat in & of itself. VW/Audi is in the process of setting up 300+ mile EV infrastructure with 600V - 15 min - 80% recharge times. Even teslas recharge @ 120kW's - so claiming 6kW's is fast can only remotely
    be considered 'moderate' if it's compared to 120V - 1kW charging. It's just that charging & discharging at high rates while being encased w/in confined areas necessitates a more expensive / complex thermal management design. Heck - our home's AC pulls ~25% more than 6kW's.
    But a residential AC isn't so confined - and has a mongo noisy fan that moves huge amounts of (hot) air. Not the same as a confined battery traveling across a hot desert, but electric appliance / thermal conditions have similar issues to overcome-deal with.
    #72 hill, Oct 13, 2017
    jaqueh likes this.
  13. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Not that it's much consolation but it could be worse - the Sonata and Optima plug-in hybrids have their 9.8 kWh batteries in the trunk up against the rear seats, preventing the rear seats from folding down like they do in the regular hybrid versions. Basically crippling carrying capacity, especially for long items.
    On the flip side, the Ioniq plug-in (already released in Europe) has its 8.6 kWh battery located under the rear seats, freeing up rear cargo space. The difference with Ioniq is that the same platform was built for electric, regular hybrid, and plug-in hybrid. However this could be why the Ioniq is reported to have less headroom for rear passengers, since the rear seat area has to also accommodate the electric model's 28 kWh battery.
    Assuming that Toyota has no plans to make an electric Prius, maybe they could place a reshaped plug-in battery under the rear seat and stick their beloved solar panel batteries in the donut hole, so cars with the solar option don't get a spare tire. Of course they could eliminate the donut spare in all models but I'm guessing that is too polarizing for them to consider that yet
    #73 Since2002, Oct 13, 2017
    jaqueh likes this.
  14. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    I am not exactly sure what your point is. You say air cooling is dangerous, and yet that is how the Prius cools the battery. You also say that 6kwh does not create a lot of heat. To get that 6kwh, you have to put in 8kwh. 2kwh turns into heat. Put a 2 kw electric heater in the trunk of your Prius and run it for an hour. Actually, don't. Too dangerous. That is what the 4 inches is for. I am not sure what your home A/C has to do with the battery heat. A liquid cooled system would be a lot more efficient, but the technical issues and higher cost make it currently impractical.
  15. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    That's not what the 4 inches of gap is for - the Prius vents things to atmosphere.
    Also, it takes longer than an hour to charge the Prime (it takes over 2 hours), so even with your example, it'd be a 1 kW electric heater, not a 2 kW one.
    But, that example is wrong - the EPA's range and efficiency calculations are based on plug power - at 25 kWh/100 mi, and 25 miles electric range, you're looking at 6.25 kWh of plug power - you're not losing 2 kWh to heat.
    hill likes this.
  16. RonMc5
    RonMc5 Member
    89
    73
    Santee
    That is why I put the beer can under there. It came within a fraction of an inch of fitting in vertically, and the full length and width of the battery... perhaps a bit less above the sound deadening material.
    wjtracy likes this.
  17. hill
    8,898
    just checked & there is no such word as "dangerous" in any of my text.
    again - no i didn't say that either. The statement referred to amounts of heat in relation to the minimum & maximum that electric cars charge. Heat generated via electricity turns on how much is passing through whatever gauge wire & the appliances ability to handle it. So that whole notion is somewhat of a tangent.
    i'm sorry but if you have 220V & multiply the typical 30 amps that gets drawn by a J1772 you get 6.6kWh. If you presume the prius draws 8kW's just to get 6, that would mean the charger has an efficiency of less than 80% - in stead of over 95% & NO EVSE is that inefficient.
    it was just an illustration, but if if is not understandable, feel free to presume I'm just incomprehensible & unable to make a decent illustration .... & I can live with that. It's not that I'm impatient to help someone understand illustrations, I just fear that a further illustration might further add to what is apparently confusion
    jaqueh likes this.
  18. Lee Jay
    5,850
    4,036
    No, those numbers are totally wrong. To get 5.7kWh, I had to put in 6.3kWh, but that difference is both for charging and for discharging. In reality, most of the loss is during discharging. The battery charging is likely to be over 95% efficient (closer to 99% most likely, if you ignore the charger itself). Thus, a 3.3kW (L2) charge will produce less than 5% or 165W of heat. That's a little more than the heat from one human body, and about 1/10th the heat from a hair dryer. It's less than the heat produced by a desktop PC, which is cooled by a little 5" muffin fan, in many cases. It's nothing, especially when you have to heat up an entire hundred-pound battery (over 200 if you include the container) with that little bit of heat.
    jaqueh and hill like this.
  19. RonMc5
    RonMc5 Member
    89
    73
    Santee
    Many of you seen to disregard the two forced air blowers that blow air directly into the battery pack from the back edge. The plenum goes almost 1/2 way across from the blower on the left, and the other half is covered by the blower on the right. Both are fed from the vent to the left and right of the rear passengers. The ALMOST half X 2 leaves room for the exhaust plenum in the middle rear... that I believe exits below the car. I tried to detect the exhaust under the car, but there a plastic plenums and covers under the car that cover the area I saw the exhaust port aiming for from the top.
    Please note the left and right black plenums feeding forced air into back of the battery pack. In the center (in front of the same MGD can) is what I take to be the exhaust port. The tube comes out the back, goes to the bottom of the car turns to the left and then straight down and through the bottom. You can see where it exits below the largest socket in it's holder. As I said above this area under the car is covered by a bunch of plastic, and I got sick trying to remove it. (Adult onset claustrophobia? Neck doesn't like to be craned any more? I am at a quandary to explain it. Note: I am 74 and had no trouble in my working years! I retired at 70.5.)
    Mark57, bisco and Since2002 like this.
  20. Trollbait
    12,653
    They said, "That's the best we can do, with what they gave us."
    Except there is already a sizable gap between the road surface and the bottom of the metal pan to make room for the muffler and suspension.
    I wouldn't blame the engineers. They likely presented better options that were canned from higher up because of costs.
    No, the battery Toyota wanted was smaller capacity. Like the PiP's, because they were still thinking home market only. Then Toyota USA told them that would not sell here.
    Several car models since the Pinto have placed the fuel tank between the rear axle and rear bumper without issue.
    The incidence of fire in the Pinto was within what other cars of the time had. The real problem with the car was its tendency to stall, leading to being rear ended.
    Back to the Prime. Honda gets amazing usable space in the Fit by placing the fuel tank under the driver's seat. Why wasn't that an option for Toyota.
