Optimal MPG on Prius Two Eco 2016
Discussion in 'Gen 4 Prius Fuel Economy' started by carlos umana, Oct 13, 2017.
  1. carlos umana
    carlos umana New Member
    Pembroke Pines Florida 33027
    Hello pals: my interest is telling to all others owners of the new prius 2016 & 2017 that my experience with my new prius eco 2016 that the MPG its almost fantastic if the person drive according with the car. I got easily 64 MPG without effort! And by the way, I got yesterday october 12/2017 83.1 MPG driving carefully to the limit of the car... In my humble opinion it's really difficult get other car than can be better that Prius in economy and quality, Prius is reliable to the limit. There are others cars more expensive or plently of gadgets, but not with the characteristic of Prius, than can travel fron Key West to Alaska go and return without problems... When the electric car arrive in the next future everybody must recognize than Prius was the game changer after almost 100 years of the same car type... No more for today. Bye and hello everybody...
    pilotgrrl, RCO, Tande and 5 others like this.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    Welcome aboard
  3. bisco
    52,351
    congrats, and well said!(y)
  4. benkhanobi
    benkhanobi Member
    123
    SW Florida
    The 2 passenger Honda Insight hybrid 5-speed was a solid 65 mpg car- sometimes over 70. Good to know the Eco is such a great hybrid.
  5. gabacho
    gabacho Junior Member
    memphis
    I too have a 2016 Eco. I don't rely on the computer to give me my mpg. I keep a written record of gallons bought. I was getting over 72 mpg on driving in town but soon I hope to make a few trips driving 70 mph on interstates. Bye, bye 72. Hello 50?
  6. Mendel Leisk
    41,863
    Yeah, note the odometer reading at each fillup, and save your gas receipts, that's all you really need. I do reset trip meter at fill up, but only for reference, rely on the odometer: it is too easy to accidentally reset a trip meter. Also if you do a battery disconnect for whatever reason, all the trip meters are gone.
  7. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    Once you learn the nuances of the car you'll figure out how to drive and get mileage most people can't even comprehend.
    [​IMG] [​IMG] [​IMG]
  8. Joey driver
    Joey driver Junior Member
    Orlando
    I recently read this post and thought no way.. so I traded my 2011 Prius with 235k Miles for a 2016 Prius Two Eco with 103k miles.
    Wow. My first tank of gas was 64mpg. My second tank I'm at 67.5 and I fill up again tomorrow. I appreciate this information you passed on to me!
  9. Mendel Leisk
    41,863
    Those values are what the dash tells you? Do keep in mind Toyota can’t resist “improving” the mpg display, by approximating 7~8% (as evidenced by comparing to calculated). That aside, 4th gen does improve significantly over the previous gen.
    from reports here it appears they’ve finally kept it honest, with 5th gen.
  10. Joey driver
    Orlando
    I verified my second tank. The car reported 69 mpg, the refill was 558 miles on 8.584 gallons = 65 mpg so you are right the dash is 6% generous.
  11. Mendel Leisk
    41,863
    Yeah it bounces around a bit, likely due to vagaries in how the pump shuts off. Toyota has "motive" and "opportunity": it makes the car more impressive, cheers up owners. Frustrating though, with mpg that's very good to begin with.
    65 mpg is crazy good, way out of our reach, 3rd gen, and doing more short trips I guess.
  12. Optimus
    Optimus Member
    274
    25
    In winter with highs barely at 10F, and lows around -10 to -20F, we got 50.1mpg on our 2016 IV. This is with 15” Blizzak snow tires on too. VERY impressed with the improvement in mpg over our Gen3 Prius.
    I expect to get near 60 by summer once temps are warmer and I put the summer tires back on. 493.1 miles, 9.833gal at fill-up. A mix of some highway driving at 55-60mph, and a lot of in-town short trips (that drove mpg down).
  13. Joey driver
    Orlando
    I'm getting better at operating this hybrid. On flat Florida land at 75 to 80f and very little wind...my last tank reported 700 miles at 70.8 mpg. The gas pump showed 10.250 and then it started spilling out. 20250228_213723.jpg 20250228_214236.jpg So I was definitely fully refueled. 700.8 miles ÷ 10.250 = 68.37 mpg.
  14. Mendel Leisk
    41,863
    That’s not beneficial, for a lot of reasons; just stop when the auto shut-off on the nozzle first activates. Any vagaries in the fillup amount will balance out on the next.
  15. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    FWIW You might want to do a little research on the negative effects of “topping the tank off”. It can get rather expensive.
  16. Fubar XIII
    Fubar XIII Member
    63
    39
    Metro Detroit
    I pulled my motorcycle (650 lbs) on a 300 lb trailer up I-75, I-65, I-69 & I-94 when I moved from Florida to Michigan in Sept. '23. My car was full of stuff (TV, two computers, clothes, beer). I drove at 65 mph max, cruise controlled, with it in Normal mode (Eco was not going to work I found out very quickly!) I managed about 44 mpg instead of my standard 56-57 avg.
    Over 70 mph sucks fuel. In fact, I try to stay 65-68 on the highway but the ever-speedy Detroit drivers force me higher at times.
