Cleaning the engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTeam, Jul 12, 2006.
  1. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Can I take my garden hose with sprayer and just hose down my engine area?
    It is all dusty. Will I hurt anything if I just hose all the dust away?
  2. brandon
    brandon Member
    771
    Manhattan, KS
    From page 379 of the Owner's Manual:
    ... so I would say it isn't a great idea.
  3. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(AlphaTeam @ Jul 12 2006, 08:17 PM) [snapback]285421[/snapback]</div>
    Better to take a slightly damp rag to it. And then you one of those air spray dusters if need be.
  4. bwilson4web
    16,186
    <div class='quotetop'>QUOTE(AlphaTeam @ Jul 12 2006, 10:17 PM) [snapback]285421[/snapback]</div>
    You need to be careful around the power leads:
    That black box that on the right of the photo provides MG2 power has a small vent tube. If it is warm and the cold water hits it, the air inside will contract and suck in whatever is around. The problem is a conductive water can trigger a ground fault error code. The Toyota repair action is to 'replace the transaxle' . . . a bad thing. But sometimes things need to be cleaned.
    You want to avoid washing a 'hot' engine and keep the water spray away from the power leads. If you do get a ground fault, let the service department know you were washing the engine and they may be able to go in and dry out the problem.
  5. Tideland Prius
    16,547
    or use a duster or small sweeper to sweep the dust away then use a damp cloth.
  6. richard schumacher
    7,664
    1,046
    United States
    You can, but you don't want to. Along with the warning in the owner's manual, notice all the waterproofing seals inside the compartment designed to keep water out.
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    use a damp cloth or some other duster- like a featherduster maybe? water in the wrong place is very bad.
  8. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    You all are so boring.
    I say "Hell yeah!!" Go for it!
    Make sure the car is ON and grab one of the orange cables before you spray it. "Hey y'all, watch this!"
    p.s. I promise to vote for you at the Darwin Awards.
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I do it twice a year, but be sure to pull the ignition coils and blow out all the water from the sparkplug tubes. Here on the wet coast mother nature can keep every thing as wet as your garden hose can. Use a fine mist spray and a bio-degradeable cleaner/degreaser. Do it with the car powered off. Then every hi-voltage feed is off.
