When Do I have to change my engine air filter? ('07)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GeorgeMW, Oct 18, 2017.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    the title says it all :)
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    User manual says Check Air Filter at 15k miles; Replace Air Filter at 30k miles for 2nd gen in the US. This can probably be stretched if you take the air filter out and blow it out with an air gun periodically.
    Obviously this is for normal service - if you drive a lot of dirt roads I'd probably replace every 5-10k miles.
    GeorgeMW likes this.
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    When it starting turning black. I blow it out then i wash the car
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    If it is a pleated paper filter, you should NOT be blowing it out.
    That only removes the BIG particles and imbeds the tiny ones even tighter.
    If it LOOKS dirty, then it IS and should be replaced.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I check mine every 5,000 miles and change it if/when necessary, it takes all of 30 seconds, and I hate paying the dealer $35 for such a simple job. Same goes for the ICE air-filter! (hint: sometimes it helps to RTFM! :rolleyes: )
  6. Mendel Leisk
    41,898
    I've yet to change ours, at 70K kms, nearing 7 years ownership, it still looks near-new. (n)
    But yeah, this is something I would only do when it's getting fairly dirty, and best not to blow it out. Tapping is ok I'd say.
    WilDavis likes this.
  7. bisco
    52,386
    so, has it not been changed in ten years?
  8. WilDavis
    2,493
    2,155
    49
    I think I'd agree (…and so would Adam Fulara, I bet! :rolleyes:)
  9. bisco
    52,386
  10. Mendel Leisk
    41,898
  11. chelvis
    chelvis Member
    85
    Long Valley, NJ
  12. bisco
    52,386
    yes, yes it does.
  13. Patrick Wong
    18,210
    6,513
    Remove the pleated paper air filter and hold it up to the sun. If you don’t see light coming through the filter then replace it. Compare to a new filter if any doubt.
  14. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    It is pretty small, but the engine is too and does not run much compared to non-hybrids. All-in-all, it depends on your driving. If you live in a urban area the filter will easily last 60k miles regardless of time. If you live in a rural area with dirt roads, plowing of fields or Las Vagas with dust storms, about half of that, maybe less.
    It is SUPER important to understand that a dirty filter *might* reduce mileage a little, but they FILTER better! So over-servicing the air filter is the WORST thing you can do to an engine aside from not changing oil. Also, not all filter are created equal, numerous quality tests have been performed by highly motivated folks with NO BIAS and generally OEM or ACDelco trap the most dirt yet have the lowest restriction.
    High Flow air filters do a TERRIBLE job of trapping dirt, it is not what you CAN see on the filter that matters, it is what made it thru that counts.
    valde3 and Mendel Leisk like this.
