New Prius V spotted (links included)
Discussion in 'Prius v Main Forum' started by stephensprius, Oct 19, 2017.
  1. cjecpa
    cjecpa Member
    160
    58
    I wanted a new Prius since it came out in 2016 however, I needed more space. I looked at the V but with the new Prius I was waiting for either next generation V or RAV4 hybrid. I hope that Europe is not the only one's to get the next generation V really can do without AWD.
  2. hellonearth
    hellonearth Junior Member
    35
    pilotgrrl likes this.
  3. cjecpa
    cjecpa Member
    160
    58
    Quite a few articles glad to see the interest as I thought the V was dead.
    All-New Toyota Prius V Spied Track Testing
  4. bisco
    52,286
    if this comes, it is.
  5. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    Why because it has a 1.5 liter engine?
    Or because it's FE will likely be lower?
  6. bisco
    52,286
    if it's a cuv, is it a v? i guess they can call it whatever they want, but to me, a v is a wagon.
  7. Tideland Prius
    16,604
    Quite small rear doors... perhaps part way between a CH-R and RAV4 in size?
    Basically the Prius SUV, sorry CUV that they wanted to re-energize hybrids. It may not have as much space as the Prius v. It will ride higher (guesstimating 6" ground clearance).
    Long suspension travel, comfortable and solid stiff chassis (But not overly stiff.. rear outside wheel is still on the ground under hard corner)
    @bhtooefr , what do you think?
  8. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I'm not 100% convinced that this is a Prius at all - I agree that those certainly look like Gen 4 headlights, but Toyota's entire styling direction is to go that way.
    I'm wondering if this is actually the new RAV4.
  9. Rmay635703
    2,669
    1,691
    2013 Chevy Volt
    I'm no fan of minivans either, if they can make it get 50mpg in that format my reluctance is lower but if it's a glorified small RAV4 with MPGs to match my interest goes to zero.
    Anyway,
    I have been wanting to get back into crafting (a hobby that used to pay) and a longer streamlined plug in V with 50mpg would do the trick if interior space was improved slightly but my interest in a transport vehicle is pretty narrow, the current V with a plug and 50 mpg would still be better for me than yet another minivan called a CUV
  10. DonD
    DonD Member
    56
    43
    New York, NY
    Double wishbone at the back? Definitely in the Prius footprint
  11. cjecpa
    cjecpa Member
    160
    58
    Give me a car like ride, 200hp, 30 cu ft of cargo room behind the rear seats and 50 mpg, you can sign me up. I can lower it like I did my Forester XT then it will look more like a hatchback kind of like the CX-5.
    #31 cjecpa, Oct 22, 2017
  12. soldierguy
    soldierguy Active Member
    108
    245
    Maryland
    Color me VERY interested. Given my commute, I've put a lot of miles on my '16 Prius eco very quickly (just had the 80,000 mile service done this morning, after owning it for 1 year, 5 months, and 22 days). This could be a great replacement when it's time to get another vehicle.
    I'm willing to take an mpg reduction in exchange for more space & comfort, as well as a higher seating position. Before getting my '16 Prius, I considered the current V, but it was a little on the noisy side, and my 6'6" husband's knees were up against the dashboard when in the front passenger seat. He ran into the knee vs dashboard thing with the RAV4, plus the fuel economy on those is not all that good, even the hybrids.
    I'd also like to see a larger fuel tank than on the regular Prius...in mine, I can make two round-trip commutes before needing to refuel. If I could do the same in a new V, I'd be happy. It's not a deal-breaker, but hitting the gas station every day gets old after a while.
  13. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    And if RAV4 is told to be plugged-in soon, why not this Priusv?
  14. bisco
    52,286
    is it? barely got the prime plug in, and an afterthought at that.
  15. Tideland Prius
    16,604
    RAV4 PHV is tempting! But if the Outlander PHEV is any indication, it will be pricey.
  16. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    StephensPrius - Thank you very much for the information on the "Appears To Be" a GEN II Prius v(vee) you shared. I thought I was going to have to consider the more fuel-thirsty and heavier Sienna Hybrid, set to come out in US/NA next Model Year, as a candidate replacement for my Versatile v(vee) Wagon.
    Model Year 2019 will work very well for me because the 2012 Prius v(vee) 5ATP, which I have in the Family Motor Pool, will be converging on the 100,000-miles Traction Battery warranty expiration mileage about then.
  17. Rmay635703
    2,669
    1,691
    2013 Chevy Volt
    Make the v the dedicated PHEV then, purpose built ;)
  18. bisco
    52,286
    you should be running toyota!
  19. telmo744
    2,181
    769
    Portugal
    Perhaps too soon, because the current generation was launched in early 2013, and normally lasts 6-7 years?
  20. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Well, it launched for model year 2013, and a new RAV4 would be launching as model year 2019 by the time one's actually revealed...
