Gen 4 cells in a Gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TampaPrius.com, Jan 16, 2017.
  1. Kevin_Denver
    Kevin_Denver Active Member
    581
    421
    Denver, CO
    This is exciting to hear! I know for the gen 3 cells, there are incremental improvements like less internal resistance and some other improvements versus the gen 2 modules. I imagine the same is true for gen 4 modules. When you finish, I'm curious to know if you notice any changes to the car's behavior versus a normal gen 2. If the modules are a bit more powerful, I could image a touch more "spunk" to the accelerator pedal when using electric power.
    #21 Kevin_Denver, Feb 4, 2017
  2. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    The big question is whether or not a Gen4 lithium battery would work in earlier NiMh equipped vehicles. I assume that a 2016 lithium battery would be a direct swap with a 2016 NiMh unit. But could you move the lithium cells and ECU from a 2016 to a Gen2/Gen3 case and it work?
  3. Kevin_Denver
    581
    421
    Denver, CO
    I would not expect the lithium ion cells from the Gen 4 eco model to be compatible with a gen 2 or gen 3 Prius, whose ECUs are programmed for NiMH. The battery technology is completely different and the batteries will behave differently under load, use a different range of state of charge, etc, and therefore require the car's ECU to be programmed specifically for it. Tampa is swapping NiMH cells from the non-Eco Prius, which should behave close enough for the gen 2 or gen 3 to work with them (probably have slightly superior performance by lower internal resistance or other factors).
    Tampa, do you have an update since January?
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    That is probably why he suggested swapping the ECU too.
  5. jerrymildred
    jerrymildred Senior Member
    11,491
    14,099
    Tampa, FL
    Cool! I just discovered this in a reference in another thread. Great work, Todd @TampaPrius.com!
    Just as a point of reference, Mildred's '07 with the 2015 cells does seem spunkier than I remember any of our previous gen 2 cars feeling. Maybe not spunkier, but crisper! Livelier? Not sure how to describe it.
    Montgomery and Kevin_Denver like this.
  6. Prodigyplace
    11,696
    11,317
    Central Virginia
    @jerrymildred may be able to get an update from Todd.
    The 2018 HyCam SE and XLE are NiMH too.
    I wonder would Gen 4 LiIon or Prime modules work in the PiP? I am sure there are Gen 4 wrecks but not many PiPs have yet needed the battery.
    Another project for Todd?
  7. Kevin_Denver
    581
    421
    Denver, CO
    Ah, missed that, sorry. I don't think an ECU swap would work as the HSD and engine are different in the gen4 as well. A full drivetrain swap might be possible for a modder ready for a serious challenge.
  8. Prodigyplace
    11,696
    11,317
    Central Virginia
    That could be at the level of the Firebrid project.
    Firebrid: The Prius v Powered Hybrid Convertible | PriusChat
  9. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Update
    This battery went into a customers car about the same time I built it. I have not heard from them. If there were any issues I'm sure I would have.
  10. TampaPrius.com
    461
    296
    Tampa, Florida
    I just did another one from a wrecked 2017 with 2k miles. It is available for installation. $2200
    m.wynn, Raytheeagle and jerrymildred like this.
  11. jerrymildred
    11,491
    14,099
    Tampa, FL
    I see you now have a Gen 4 in stock. Sweet!! Sure wish I was in the market.
  12. Prodigyplace
    11,696
    11,317
    Central Virginia
    @TampaPrius.com needs to update Web "About Me".
    ...I currently stock 2nd generation (2004-2009) models. ...
    I believe you stock more (and newer) than that... :D
    jerrymildred likes this.
  13. Prodigyplace
    11,696
    11,317
    Central Virginia
    2016. 2. Spare tire but no advanced safety features.
    The listing says "Front fog lights" but the photos show the stock blank covers, I think.
  14. TampaPrius.com
    461
    296
    Tampa, Florida
    Thanks, I updated the listing.
  15. Prodigyplace
    11,696
    11,317
    Central Virginia
    I am interested in your opinion. In another thread about flooded Prii, somebody is looking at a 2016 with no traction battery. Assuming it is not Trim Two, do you think a PiP battery would work? We know they are both Li-Ion.
    I thought there were differences in the battery packs among generations even though the modules are compatible.
  16. TampaPrius.com
    461
    296
    Tampa, Florida
    No, it will not work. Only put the same type of battery that originally came in the car.
    m.wynn, jerrymildred and Prodigyplace like this.
  17. Woodchuck
    Woodchuck Junior Member
    25
    26
    Menlo Park, California
    Did the Gen 4 battery just bolt right in? What about the electrical connections, etc?
    iPhone ? Pro
  18. Prodigyplace
    11,696
    11,317
    Central Virginia
    The modules from a US Gen 4 Trim TWO (not Eco) can work in an older generation battery pack. The other trims have a different battery chemistry that is not compatible with your vehicle.
    The battery packs are not interchangeable between generations.
  19. jerrymildred
    11,491
    14,099
    Tampa, FL
    You have to transplant the cells from the Gen 4 battery case to the Gen 2 battery case.
    Raytheeagle and Prodigyplace like this.
  20. Prodigyplace
    11,696
    11,317
    Central Virginia
    ONLY if the Gen 4 is s Trim Two!
    You cannot safely put the Li-Ion battery modules in older generations. The exception may be the plugin Prius but nobody has tried that yet.
