Voice command to control A/C fan speed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ChrisA, Jul 10, 2006.
  1. ChrisA
    ChrisA New Member
    Round Rock, Texas
    Whenever I use the Voice Command to enable the A/C, it turns on as expected but the fan speed is always on high. Prior to shutting it off each time, it is not left in that speed so I am not sure why it selects that speed when it is enabled via the voice command.
    Does anyone know a voice command to control the fan speed? I have not been able to find one in any of the posts here, or in the Toyota provided material. Ideally, I wish it would not select high as the initial speed, but short of changing this, it would be nice to alter it via voice command.
    Chris
  2. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(ChrisA @ Jul 10 2006, 08:43 PM) [snapback]284270[/snapback]</div>
    As far as I know, there is no voice command to control the fan settings. The AC voice command works the same as pushing the AC button on the steering wheel. In most cases this means it comes on HI and in the outside air mode.
    The only way this does not happen is to select AC on the MFD or push the LO and if AC was already on before it will kick on again...if not select your speed and then click on AC on the MFD.
    FYI, here is a list of voice commands compiled for the system by others
    2006 Voice Commands
  3. ChrisA
    ChrisA New Member
    Round Rock, Texas
    <div class='quotetop'>QUOTE(mssmith95 @ Jul 10 2006, 11:04 PM) [snapback]284279[/snapback]</div>
    Thanks for the reply. I could be mistaken (will verify it tomorrow), but I thought that when you enabled the AC via the MFD, it started at the fan speed that it was previously set for on the last enablement. Just curious why the voice command would not behave the same. Not much of an effort to slow down the fans via the old fashioned method, but thought there should be a way via voice command. Again, thanks....
  4. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(ChrisA @ Jul 13 2006, 08:23 PM) [snapback]286038[/snapback]</div>
    Well the main problem is that if you use either the AC/AUTO button on the steering wheel
    OR
    The voice command "Automatic Air Conditioning"
    You are really turning on the "AUTO" feature. The Auto feature seems to normally trigger the highest fan setting along with the outside air setting.
    As far as I have been able to tell, there is no voice command for the fan levels.
    You are correct about the MFD. If you previously had the AC on but the fan off on you can then select the fan speed and the AC comes on at that speed. If you have the fan on already and click AC then the fan setting stays at that level while the AC comes on.
  5. StevenD
    StevenD New Member
    Oregon
    2020 Prius Prime
    I am disappointed with the fan control on my Prius. It is hard to increase or decrease fan setting on the LCD screen while driving. It is dangerous. Am I missing something? No manual controls…….
  6. bisco
    52,286
    anything in the owners manual?
